    Tires, What works for you?
    Number of posts : 698
    Registration date : 2015-12-09
    Tires, What works for you? Empty Tires, What works for you?
    Post by Russell Wed Mar 21, 2018 1:03 pm
    What type of tires are you running? How do they last, drive etc.?
    I did a search for "Tires" and did not find any real info on what type of tires work well on our Vans.
    I have 15x6" wheels all around running 215/70r/15 tires, Yokohama Avid touring S.
    I'm thinking of getting some BF Goodrich T/A Radial's the same size.
    I would like to know what you run and how you like them, how they drive, how they wear etc.
    I had 60's before the 70's and it is much easier to steer with the 70's, 78's steer easier but I like the width of the 70's.
    I guess I should ad it's a '66 Chevy 90" Sportvan Deluxe
    SteelyVan
    SteelyVan
    Number of posts : 112
    Registration date : 2009-08-15
    Tires, What works for you? Empty Re: Tires, What works for you?
    Post by SteelyVan Thu Mar 22, 2018 7:54 am
    Running 15X7 wheels all around with BFG TA's. 2,000 miles on them with good/great wear so far. Fair weather cruising on two-lane roads (411 rear). Rides and steers awesome despite original spring hardware/bushings!
    215 front
    255 rear
    Post by Russell Fri Mar 23, 2018 5:08 am
    When I got home from Home depot I found this, still holding air but my tread is getting thin anyway.
    Tires, What works for you? Img_1112
    caleboh
    caleboh
    Number of posts : 48
    Registration date : 2017-12-26
    Post by caleboh Tue Jul 17, 2018 3:21 pm
    The Cooper Cobra Radial is a good alternative to BFG Radial T/A. Less pricey and has a good treadwear rating. I currently run these cooper tires and I'm very pleased with how they handle. They are quite good on wet pavement also.
    Post by vanny Tue Jul 17, 2018 11:02 pm
    Russell wrote:When I got home from Home depot I found this, still holding air but my tread is getting thin anyway.
    At least it's got a washer to help hold in the air...a friend who drives a 66 GMC is running Cooper Cobras as well and tells me they wear and handle very well. Less expensive than the BF's and good wear...
      Current date/time is Thu May 09, 2024 11:44 am
