I AM HAVING A PROBLEM WITH THE EMBLEMS ONTHE FRONT OF MY A-100 THE LETTERS D O D G E BELONG ON THE FRONT OF THE VAN I TRYED PUSHING THEM INTO THE HOLES AND THE FEMALE PART INSIDE THE HOLE POPED IN SIDE THE BODY ??? HOW DO I INSTALL THE LETTERS D O D G E NOW??? IF I KNEW OF THIS PROBLEM I WOULD HVE FILLED THE HOLES IN BEFORE I PAINTED... ANY HELP ??? PLEASE... THANKS DIX...
a100 emblems
- Number of posts : 8732
a100 emblems
jkr- Number of posts : 1148
Re: a100 emblems
"3-m two sided tape". best there is. and you still use the holes for alignment. take a few wheel weights and a propane torch to melt them and fill the back side of the letters to get more contact area for the tape if needed. the surface needs to be clean and rough for the lead to stick but it will and you can file the high spots with a file..........good luck.jeff
