So I have the floor pans and have disconnected everything on the floors. I have officially started to cut out the front floors. How should I attach the new pans to the frame, the wheel well, and the front part of the floor that is staying? Should I spot weld evrrything and use a sealer or should I try to run welds the length of everything? I need some ideas I don't like either of those options but that's what I'm seeing???
Need some ideas
ramian09- Number of posts : 167
Registration date : 2010-01-26
Need some ideas
Re: Need some ideas
I did some of both, spot weld and seam weld. Depends on the location. When the floor is on top of something, like a frame rail, then spot welding for strength is fine. If you're trying to butt-weld the floor to another piece of floor, then weld the entire seam. If you can create a flange so the old and new overlap, spot welding is okay but I would probably still do the entire seam.
Clean both sides of the existing floor that will stay. You want to get all the way to clean metal. Rusty metal and old paint don't weld good.
Re: Need some ideas
Awesome thanks for the advice. That's probably what I'm going to end up doing. If I spot weld to the frame should I try to seal it with anything so water doesn't get in the frame? I've looked around and the frame is not water tight as it sits. But I will probably be exposing some raw metal in around and on the frame .
Re: Need some ideas
I'm a big fan of sealing every little seam with seam sealer. Doesn't cost that much and it's good insurance. And, of course, good paint as a final step.
Vanner63- Number of posts : 235
Re: Need some ideas
Assuming you are using a TIG welder, spot weld your piece into position. Then, carefully weld all seams. You have to remember these vans and trucks are unibody and the floor pans and all flooring panels are considered structural. Not welding completely will allow stress on a spot weld that could break causing issues with the structural integrity of the entire van. Don't over build on your weld seams. Then you have to do a lot of grinding. ( Pain in the butt.)
Once you have a clean welded seam you can then use the sealer for a better appearance.
The main thing is that if you don't weld on a regular basis, take your time and have patience with the process. If you can afford it, have it done professionally. In a pinch, I have farmed work out rather than get in a hurry and mess it up.
Re: Need some ideas
Thanks you guys that is all good advice I'll wood and seam seal. No unfortunately I'm using a Lincoln buzz box yep sure it's going to be the key.
Buddyr- Number of posts : 48
Registration date : 2015-10-08
Re: Need some ideas
I have been using a weld thru primer on all the frame tops and bottom of panels. Basically anywhere you won't be able to paint later.
mnghost- Number of posts : 64
Registration date : 2013-08-28
Re: Need some ideas
You may want to read thru the posts this guy has done on panel repair. There are a lot of good tips for your type of repair
http://www.garagejournal.com/forum/showthread.php?t=182565
