by RodStRace Sat Jan 07, 2017 11:45 am
Glad to hear you have been researching for a while!
Suggestions for reviving the van, since it was towed I assume it wasn't a driver when gifted...
Lubricate everything! I you have a manual, it's all laid out in there. If not, grab a grease gun, wire brush and a few rags and go underneath and hit every zerk fitting you can find. These include manual shifter through the grille, pedal pivots, steering linkage, U-joints. Find some rubber lube for spring bushings. Silicone spray for window rubber (and glass cleaner for after!) Don't forget wiper refills (not full black plastic blades) if it's still rainy like the first picture.
White grease or PB Blaster for door latches, handles and hinges, window regulators, vent window pivots, seat tracks and pins, nuts and bolts you plan on removing. Also shifter cable or shift linkage and E brake handle, wheel, cable and pivot.
Graphite for locks, NOT oil-based spray.
Then replace fluids as you can find the time and money - brake fluid, coolant, oil, transmission, diff. Adjust the brakes and parking brake too.
Clean battery cable ends and ground connections, along with ammeter connections and fuse clips. Check all light bulbs.
Doing this will help you get to know the van better and make it wake up smoother.
Some glass cleaner followed by chrome polish on a rag (or "00" steel wool for rust spots) will get those Cragar SS's nice again. Make sure the lug nuts are tight before your first drive! Are they still left side left-hand thread?
It's a good idea to have one battery terminal loose enough to be removed in case of fire at first, and bring an extinguisher along.
Looks like a great start, a Custom Sportsman with most of the trim still there. Is it a /6 or V8, auto or manual? What year (guessing 1967-68)?
