    '69 A108 Reverse Light Wiring
    DueNorth
    DueNorth
    Number of posts : 28
    Registration date : 2016-10-22
     '69 A108 Reverse Light Wiring Empty '69 A108 Reverse Light Wiring
    Post by DueNorth Fri Nov 04, 2016 10:48 am
    Hi Chaps,
    Can anyone help?
    My reversing lights are currently wired to a seperate switch on the dash(which is a bit of a pain)
    I would like to reconnect them to the gearshift lever
    Can anyone please share a diagram of how they originally connected ( I have ordered the repair manual on dvd-but it's not going to arrive for 2 weeks!)
    Thanks
    Mike
     '69 A108 Reverse Light Wiring Empty Re: '69 A108 Reverse Light Wiring
    Post by donivan65 Fri Nov 04, 2016 1:54 pm
    is it a manual or automatic transmission? Are the back up lights factory or add ons?
    jeepsterhemi
    jeepsterhemi
    Number of posts : 79
    Registration date : 2012-02-20
    Post by jeepsterhemi Fri Nov 04, 2016 2:01 pm
     '69 A108 Reverse Light Wiring Back-u20
     '69 A108 Reverse Light Wiring Back-u19
    jeepsterhemi
    jeepsterhemi
    Post by jeepsterhemi Fri Nov 04, 2016 2:04 pm
    Must be automatic as the back-up lamp switch is on the gearshift.........
     '69 A108 Reverse Light Wiring Back-u21
    DueNorth
    DueNorth
    Post by DueNorth Fri Nov 04, 2016 2:21 pm
    jeepsterhemi wrote:Must be automatic as the back-up lamp switch is on the gearshift.........
    Yeah it is auto
    jeepsterhemi wrote: '69 A108 Reverse Light Wiring Back-u20
    Cheers for that- excellent stuff-just what I needed!
    Thanks for your help-it is appreciated
    Mike
    69
    69
    Number of posts : 434
    Post by 69 Fri Nov 04, 2016 3:03 pm
    It is a bit of a pain to remove the gearshift lever, but it works. My '69 model did not have the switch on the gearshift lever - I just mounted a modern microswitch in a proper position. Your transmission might have the backup light switch included - it is a three pin switch, located on the driverside of the transmission a little above the pan. If in reverse, the two outer pins are connected. Otherwise, they are open. Hope that helps.
     '69 A108 Reverse Light Wiring Bus
    DueNorth
    DueNorth
    Post by DueNorth Sat Nov 05, 2016 2:37 am
    69 wrote:It is a bit of a pain to remove the gearshift lever, but it works. My '69 model did not have the switch on the gearshift lever - I just mounted a modern microswitch in a proper position. Your transmission might have the backup light switch included - it is a three pin switch, located on the driverside of the transmission a little above the pan. If in reverse, the two outer pins are connected. Otherwise, they are open. Hope that helps.
    Excellent- thanks for your help
    Mike
      Current date/time is Fri Apr 26, 2024 2:21 pm
