    keep original three on the tree
    keep original three on the tree Empty keep original three on the tree
    Post by Guest Wed May 13, 2009 3:49 pm
    I have a 1961 econoline with the 144 and three on the tree, and wanted to upgrade my engine. But still want to keep a three on the tree if possible. What kind of engines would bolt up to my original trans. I would really love to run a 200ci mustang six cylinder, has anyone done this?
    Thanks for any info
    Drew
    Number of posts : 2067
    keep original three on the tree Empty Re: keep original three on the tree
    Post by sasktrini Wed May 13, 2009 3:54 pm
    Hey Drew!
    You may be able to put a 200 in there, but they had stronger crossmembers to support those engines after '64. Mine has the two arms supporting the engine mounts rather than a true crossmember. Certainly that was the '61 design. Now, my 170 isn't too bad. Your 144 must be frustrating.
    Number of posts : 2198
    Post by EconoUSAparts Wed May 13, 2009 6:30 pm
    200 is the biggest direct replacement you can use. Not sure which years but some wont work. Fred Carello from this site knows all the particulars on it. I would swap out the tranny to a later synchronized one while your at it.
    Post by Guest Fri May 22, 2009 6:04 pm
    I have a 1977 200ci Mustang motor in my 65 but it has been built with Clifford Performance 6=8 technology. Very strong and FAST.
      Current date/time is Sun May 19, 2024 10:09 am
