    King pins with the correct groove
    scarlin
    scarlin
    Number of posts : 258
    King pins with the correct groove  Empty King pins with the correct groove
    Post by scarlin Wed Mar 16, 2016 5:48 pm
    I have the tooling to grind the correct groove depth for king pin locking pin. They have not had the correct depth for a while. $50 per set in a USPS flat rate box, send the pins only, The grinder will be set up Mid April to the !st of May. It may be fall before I get set up again.
    PM here or lcarlin@voyager.net.
    Sam In MI
    Number of posts : 2086
    King pins with the correct groove  Empty Re: King pins with the correct groove
    Post by Seth G Wed Mar 16, 2016 8:03 pm
    Good deal, thanks for the info Sam. Mine are good, but I might just get a set to have in reserve.
    scarlin
    scarlin
    Post by scarlin Sun Apr 24, 2016 6:39 pm
    Last Call, need them the next 2 weeks or it will be fall before I set up again,
    Sam
    scarlin
    scarlin
    Post by scarlin Wed Jun 22, 2016 6:15 pm
    I'll be set up the again the first part of July. Aug will be the next setup
    Sam
    scarlin
    scarlin
    Post by scarlin Sat Jan 28, 2017 7:16 pm
    Next setup is March 2017, PM if needed
    Wyowanderer likes this post
    Wyowanderer
    Wyowanderer
    Number of posts : 31
    Registration date : 2022-05-15
    King pins with the correct groove  Empty King pin grinding
    Post by Wyowanderer Sat Apr 08, 2023 5:55 am
    scarlin wrote:Next setup is March 2017, PM if needed
    Are you still grinding king pin grooves? I have a set that came in a FoMoCo box, but they measure .749 and I'd like new grooves to be on the safe side.
    Frank.
      Current date/time is Wed May 01, 2024 7:33 pm
