    Starter bolts TORQUE spec needed
    Glazz74
    Glazz74
    Number of posts : 17
    Registration date : 2015-08-02
    Starter bolts TORQUE spec needed Empty Starter bolts TORQUE spec needed
    Post by Glazz74 Sat Jan 30, 2016 9:10 pm
    Does anyone know the recommended torque for the three bolts that bolt the starter in place for a 1964 170 six?
    Number of posts : 2086
    Starter bolts TORQUE spec needed Empty Re: Starter bolts TORQUE spec needed
    Post by Seth G Sat Jan 30, 2016 10:04 pm
    I always have just gone hand tight and snug with starter bolts. When in doubt go by bolt size and type, probably around 15-20#
    https://www.boltdepot.com/fastener-information/bolts/US-Recommended-Torque.aspx
    Post by donivan65 Sat Jan 30, 2016 10:12 pm
    sounds good,,,,book says 3/8" 2 hole starter bolt is 15-20,,,,,,,,,,,,,3 bolt 5/16" is 12-15 ft lbs.....
    Glazz74
    Glazz74
    Post by Glazz74 Sun Jan 31, 2016 12:27 am
    Sounds good. I had always done the hand tight/snug way before until about 15 years ago had a remaufactured starter metal shatter inside and damage the pressure plate and clutch after I just installed it. The only feedback I had received from the company that it was very important to have al the bolts equally torqued for that reason.
    Nothing like doing a quick starter swap and ending up doing an entire clutch kit.......lol.
    ***Not sure about double post but may have to do with an internet outage while I was in the middle of posting this topic.
    Post by vanny Sun Jan 31, 2016 2:59 am
    I removed the extra posting so it wouldn't be confusing.
      Current date/time is Thu May 16, 2024 7:33 pm
