On my A100 pickup project, I have the 4 wheel disc brakes installed, and am checking out master cylinders and power brake boosters. Also, trying to find a place under the floor where a decent-sized booster might actually fit.
I'm considering a used Hydraboost unit, looks like I might be able to find one at the wrecking yard and use the attached master cylinder and then an adjustable proportioning valve later if needed. It looks like there's room under the floor for the unit. Since I'm planning on installing a power steering box, I'll already have the pump installed.
Has anybody installed a Hydraboost unit in the A100 ?
Thanks
Thanks
