    Alternator lower bracket
    Marcosis
    Marcosis
    Number of posts : 25
    Registration date : 2012-11-08
    Alternator lower bracket Empty Alternator lower bracket
    Post by Marcosis Sun Nov 01, 2015 2:52 pm
    Hi Guys, I started getting a squeal from my fan belt, so went to tighten it up and found the top bolt going into the alternator broke. I figured no problem, i'll pull the alternator, drill out the broken bolt and use a through bolt instead. removed the alternator and found that the lower swivel bracket was broken. It broke before and I had it welded. It didnt last long. Any body have a source for that lower bracket. I found one off a 81 Chevy K10 on ebay, just curious if anyone knows a part # from a later year that would work, or an aftermarket solution.
    Alternator lower bracket Empty Re: Alternator lower bracket
    Post by donivan65 Sun Nov 01, 2015 5:30 pm
    if,,,,,,,,,this is what you need,   come on down and get it,,,,,,,,or PM me with your address and I will send it to you,,,,,,
    Alternator lower bracket Dscn7131
    Marcosis
    Marcosis
    Post by Marcosis Sun Nov 01, 2015 5:38 pm
    Thats it exactly! pm inbound. Thanks
    Marcosis
    Marcosis
    Post by Marcosis Thu Nov 05, 2015 9:19 pm
    Thanks to Donivan, I'm back on the road, and more motivated than ever to fix up my 66. Yesterday I ordered an hei distributor and 8mm wires, today i picked up and installed a new turn signal switch. I look forward to meeting more of the socal van guys.
    Post by vanny Fri Nov 06, 2015 3:18 am
    Don is responsible for keeping a lot of these vans on the road. We're lucky to have him and others like him on this site!!!
    Rick's 66 Chevy Van
    Rick's 66 Chevy Van
    Number of posts : 331
    Post by Rick's 66 Chevy Van Fri Nov 06, 2015 11:43 pm
    He is the best
    Marcosis
    Marcosis
    Post by Marcosis Mon Nov 09, 2015 1:22 pm
    Hey Donivan, I saw that your spring place closed and that you were checking out new solutions for spring bushings. Did you come to any new conclusions on parts or suppliers. My bushings are shot, I think that will be the next project.
    Post by donivan65 Mon Nov 09, 2015 1:51 pm
    Hey Marc,   our 1st Gen van springs  basically have 3 different bushings in them,,,,,you have the  HB 930 rubber shackle bushings,,,,,,the forward ends have the 1 1/8" metal cartridges which we put polyurethane ones with a sleeve through them instead of them,,,,,,,and,,,,,,most of the time,,,,,that metal bushing on the forward end of the front passenger spring is a bigger 1 5/8" one,,,,,,so check this post out and we can talk more about it,,,,,
    https://vintage-vans.forumotion.com/t50119p30-leaf-springs-bushings
    Post by Twinpilot001 Mon Nov 09, 2015 4:13 pm
    summitt & jegs have them also.!!
      Current date/time is Thu May 02, 2024 8:15 pm
