,,,,a look at whats in Old Skool Vics Shop,,,,,,,,
,,,,,,Just starting to get this section organized ,,,,,
greggk likes this post
albadanie@gmail.com wrote:Anybody do a coversions of some sort?
Old Skool wrote:I use the ones from Broncos and F series pickups. Easy to identify. They make two models that I have found, the CORRECT one using a RED plug in. Pull the dash back and peek inside, if its red, its the one. On the F series, there is a small plastic box, directly over the e brake lever, take the mounting screws out as one is used for the relay box. In the Bronco's, the relay box is hiddend further up inside, wrapped in foam to protect it. Careful with them as they have a warining on them that says do not drop, and they mean it.. There is a ground wire on the switch, and our 67 wiper motor has the matching correct plug on it to go into this switch. Test the units if you can,, I have a box of at least two dozen that don't act quite correctly??? sometimes the switch and sometimes the relay box.
The conversion on the switch stem is not too hard to do, it needs to be cut in length (note: careful on length, as our switch pulls out, this one pushes in, and if you cut it too close, it won't work as I recall (old age setting in,ha,ha) anyways, use a washer to shim the assembly out a little, and continue cutting the flat spot down, and cut a NEW little slash with a dremel motor for our knob to click into like the stock switch has,, Mine works great, use it all the time, and you can't tell its not stock at all.
vic
