    Wheel Studs Part #?
    Number of posts : 946
    Wheel Studs Part #? Empty Wheel Studs Part #?
    Post by BvrWally Mon Apr 27, 2009 9:02 am
    I am doing the rear disc conversion and have just about everything for a go! Got the axles at a machine shop this morning, turning the flanges down, etc. now I am in need of the longer studs. Anyone got a NAPA part number for them? The young kid at the local store...just gave me that "Deer in the Headlight" look when I asked for them?? lol
    He said 69-70 only had one size!! lol
    B.W.
    Wheel Studs Part #? Empty Re: Wheel Studs Part #?
    Post by Digz Mon Apr 27, 2009 4:22 pm
    B.W. I have an Auto Value # for some that are a little longer DOR 610-186,
    figured they would work to make up the difference of the rotor thickness I am going to use them on the front, I ended up getting longer ones yet for the rear in case i had to use a wheel spacer but I can't find the slip for those yet. These are 1st gen tho if that makes a difference.
    Post by G-Man Mon Apr 27, 2009 4:26 pm
    BW you must have some non chain auto parts stores around you??? My local place could get them in many sizes.
    Number of posts : 1651
    Post by Scott Mon Apr 27, 2009 7:58 pm
    On my front hubs I used NAPA P/N: 641-1267 for my disc conversion.
    They are a little longer then the stock bolts.
    I paid $2.05 each for them.
    Post by BvrWally Mon Apr 27, 2009 8:57 pm
    Thanks guys! I'll do some running around tomorrow for them!! lol
    B.W. Smile
    Post by donivan65 Mon Apr 27, 2009 9:43 pm
    Spex
    Wheel Studs Part #? Studs10
    Post by BvrWally Mon Apr 27, 2009 10:25 pm
    Thanks Don...I knew you'd have the info I needed!!! lol
    B.W. Smile
    Post by donivan65 Mon Apr 27, 2009 11:25 pm
    Hey Rollie,,,,,you will also be needing those longer studs if you take off those front Nova brackets and change over to the TransAm ones,,,,,,and the chart will help you if you got custom wheels which sometimes require you to change the stud lengths to let the lugnuts fit correctly.
    Post by BvrWally Tue Apr 28, 2009 3:38 am
    Thanks again Don, but I knew I had them installed already on the stock hub awaiting that swap. Problem was...I had the receipts with the part #'s and all, but I was at our home in the city and not near "my normal base of operations" where they were!!! I am getting the axles done in a city we just moved to a few years ago, and I am just now making contacts for new parts stores & machine shops and all. I had forgotten to grab the #'s when we left Sunday afternoon. lol
    Thanks for your help.
    B.W. Smile
      Current date/time is Sun Apr 28, 2024 11:44 am
