    1967 Chevy Questions
    1967 Chevy Questions Empty 1967 Chevy Questions
    Post by Guest Tue Aug 25, 2015 6:29 pm
    Hey guys. New to the whole Vanning thing. I recently picked up a 67 G10 that has a 350 in it, stock rear and 3 speed. I have a couple of questions
    This thing over heats. What radiator are you guys using or what fixes are a good idea. I bought an electric fan to push air over the radiator but haven't installed it yet.
    Converting to automatic. Thoughts? I have the stock 3 on the tree and Im thinking of changing it to automatic. I will need to fid good resources to read about this. Need the pros and cons.
    Thanks for the help[url=1967 Chevy Questions IMG_20150823_200901]1967 Chevy Questions IMG_20150823_200901[/url]
    1967 Chevy Questions Empty Re: 1967 Chevy Questions
    Post by Twinpilot001 Tue Aug 25, 2015 7:09 pm
    Ok as for the radiator=(i have a 67 gvan)-- i buy the 3/4 core alu. new radiators off ebay. Champion brand?? and as i use a side mounted flange on all my installs (chev & fords) I get ones for early/mid years chrysler cars (big cars) with 440 cube listings. These come with the auto coolers in the bottoms & side mount flanges-easy for me to mount. What you have to watch is this- chev & ford inlets & outlets are reversed from each other!!. Chrysler applications used both types in their cars - so just look for one with a chev inlet &outlets @ proper locations. prices usually run under $200.00 some with free shipping!! I also use a clutch fan =WITH!! a shroud too - they sell those (shrouds) too. As far as the trannys - I use a 700R4-built!! some like the lighter 2004r trans. But its actually a lighter duty trans. To each his own! cheers
    Post by donivan65 Tue Aug 25, 2015 10:01 pm
    the 69 came with the TH350 transmission and the 70 came with the 350 engine,,,,,,,,do you have the stock V8 cooling system on it?
    1967 Chevy Questions 2nd_ge12
    Post by Guest Wed Aug 26, 2015 6:38 pm
    What modifications would need to be done to mounts or cable hook ups needed?
    Twinpilot001 wrote:Ok as for the radiator=(i have a 67 gvan)-- i buy the 3/4 core alu. new radiators  off ebay. Champion brand?? and as i use a side mounted flange on all my installs (chev & fords) I get ones for early/mid years chrysler cars (big cars) with 440 cube listings. These come with the auto  coolers in the bottoms & side mount flanges-easy for me to mount. What you have to watch is this- chev & ford inlets & outlets are reversed from each other!!. Chrysler applications used both types in their cars - so just look for one with a chev inlet &outlets @ proper locations. prices usually run under $200.00  some with free shipping!! I also use a clutch fan  =WITH!!  a shroud too - they sell those (shrouds) too. As far as the trannys - I use a 700R4-built!! some like the lighter 2004r trans. But its actually a lighter duty trans. To each his own! cheers
    Post by Guest Wed Aug 26, 2015 6:40 pm
    Im sure its the stock radiator from the original inline. Are the parts available that I would need to hook in a th350 trans?
    donivan65 wrote:the 69 came with the TH350 transmission and the 70 came with the 350 engine,,,,,,,,do you have the stock V8 cooling system on it?
    Number of posts : 1412
    Post by Vantasia Thu Aug 27, 2015 6:33 am
    Welcome, MHO, take the stock radiator to a good shop and have it flow tested, if it can be boiled out, have that done. If too clogged and corroded, very likely, have it re-cored with a new core that have more rows and larger tubes than the stock ones. I had my stock one with 2 rows of 30, 1/2" tubes increased to 45 rows or 5/8" tubes, 40% more cooling area and brand new tubes! I run all day in 90 degree weather at 180 or less. Recoring cost more than a new aluminum that have suspect quality issues and you don't have to modify the mounting, none of them are a direct fit and copper is still better for cooling, just cost more.
    Post by donivan65 Thu Aug 27, 2015 11:32 am
    They used the normal car TH350 transmission with a special ring mount to hang the transmission in a van,,,,,,the newer 700R4 and 2004R use a made up  crossmember to hold the transmissions up,,,,,,,
    1967 Chevy Questions 700r4_12
    1967 Chevy Questions 700r4a11
    Post by Guest Sat Aug 29, 2015 7:06 pm
    So long shift cable and use the stock column?
    donivan65 wrote:They used the normal car TH350 transmission with a special ring mount to hang the transmission in a van,,,,,,the newer 700R4 and 2004R use a made up  crossmember to hold the transmissions up,,,,,,,
    Post by donivan65 Sat Aug 29, 2015 9:30 pm
    people use the 2nd/3rd shift rod to shift the trans to get by,,,,,,you have to guess what gear you are in,,,,and it will start in any gear if you dont have a safety neutral switch hooked up to the starter,,,,,,or use a cable,,,,,people use floor shifters,,,,,put them on the doghouse,,,,,and you will need a kick down or throttle cable and linkage on the carb,,,,,,,maybe even a different u joint yoke and the driveshaft shortened,,,,,
    Number of posts : 1778
    Post by m1dadio Sun Aug 30, 2015 9:43 am
    when you use an aftermarket shift indicater they most all incorprate a nutral saftey
    1967 Chevy Questions Dscn1910
    1967 Chevy Questions Dscn2010
    m1d
    Post by donivan65 Sun Aug 30, 2015 11:24 am
    ,,and it looks like a back up light switch is in it also,,,,,,,M1, do you think hooking that unit to the 2nd and 3rd speed lever would work as good as using a stock auto trans steering column?
    Post by m1dadio Sun Aug 30, 2015 8:34 pm
    you are correct it does have provision for reverse light as well. You don't haveto buy the gauge style indicator . you can can get LED display and a veriety of shift displays.
    I am using that on my 700R4 . It is attached at the trans. I habe my trans as a cable shift conected to the 2nd/3rd gear leaver of a manual colum.
    1967 Chevy Questions Dscn1911
    1967 Chevy Questions Dscn0110
    m1d
    Post by donivan65 Sun Aug 30, 2015 9:38 pm
    ,,,and like how much would that set up cost him? I see you drilled a new hole in the lever to match the movement of the cable,,,,,,,and what about that cable coming in from the rear,,,,,,what brought that about?
    Post by m1dadio Mon Aug 31, 2015 6:59 am
    I don't know what I paid. I bought a complete set of custom ordered gauges for about $1300 and that was included.
    If you want to play you have to pay, is what I keep getting told by a certain parts counter guy every time I am shocked at the price of stuff.
    One can google "shift indicator" to see the availible options and prices.
    Post by donivan65 Mon Aug 31, 2015 9:53 am
    you got some quality stuff for sure,,,,,,,and its good to see what people use and do on their vans,,,,,,as for cost, it gives them an idea if it is right for them,,,,,,,,,,,,,,its good to give people choices,,,,,,,,,,,,,,
    Post by Vantasia Mon Aug 31, 2015 12:39 pm
    Adding more, info, several have used aftermarket shifters like from Lokar, floor mount or use a console shifter and mount it on the front or top of the doghouse cover, check the threads, many pictures of these set ups. Others have transplanted stock auto shift steering columns but they are hard to find with the plastic indicator and needle intact and working, some repros are available for these parts but not easy to do.  And like Doni says, the stock tranny used a special hanger ring, very rare and hard to find, but they can be fabricated from steel stock and tubing or make a cross member bottom support like he shows, again, several threads with pictures here.  You might want to look for an auto tranny parts van if you can find one, some members here have them and may have just what you need, ask around like you did here!, Nice dog, matches the van! LOL
    Post by Guest Mon Aug 31, 2015 8:12 pm
    Awesome info! Thanks so much for the help guys. For now I think Ill get the radiator fixed and replace the front springs (they sag pretty bad) and rock the 3 speed. Id like to eventually make it more of a cruiser and take it places. The dog and the van are great, she loves sitting in the front seat.
    Post by donivan65 Mon Aug 31, 2015 8:29 pm
    well,,,,,,,,you got the weirdest springs in the World,,,,,,,,they are 3" on the ends and squeeze down to 2 1/2" in the middle to fit inside the U Bolts,,,,,,,,,you will probably have to get 2 1/2" springs and use fatter bushings so they fit tight in the perch and shackles,,,,,,,,,,,,,,
      Current date/time is Wed May 08, 2024 2:34 pm
