    Intake Manifold Question
    bugman
    bugman
    Number of posts : 72
    Registration date : 2011-12-17
    Intake Manifold Question  Empty Intake Manifold Question
    Post by bugman Mon Jun 22, 2015 5:22 pm
    Just curious... what is the machined grove in the intake manifold for? There is no hole at the end of it and I see it as a potential vacuum leak, Should I make new gasket to cover it?
    Intake Manifold Question  Carb12
    Number of posts : 2086
    Intake Manifold Question  Empty Re: Intake Manifold Question
    Post by Seth G Mon Jun 22, 2015 5:31 pm
    It's a vacuum channel. If the carb's base doesn't have the corresponding hole for the end of that groove then there's no problem with using a gasket w/o the hole.
      Current date/time is Sat May 11, 2024 9:37 pm
