I have a 69 gmc with an early 70 s 350. I've had mine worked on twice already so its time for a new one. I've read most of the previous post on the subject. The 67/70 mustang/cougar radiator that kookykrispy looks like it will work. Just wondering if anyone has used it in a second gen with a v8. Any help is appreciated.
finally going to get a radiator. help please
Arnolds Garage- Number of posts : 25
Registration date : 2013-03-23
Heres what i do - get in ebay!!!!!!!!!! Look for Chrysler cars (BIG) & Chrysler=trucks -1/2 & 3/4 ton applications. in the late 60's early 70's = maybe up to 78??-era!! They are minimum 3 core & some 4 core ones =WITH side mounts on them. What to watch out for on these is = where the water inlets & outlets are!!! They make both for chev & ford 9opposite) applications!!!!!!! usually costs below 200 bux & all usually have tranny coolers & some even come with elect. Fans!! What i suggest is also - get -or have made a fan shroud to fit these!! Your cooling problems will be a thing of the past!! Its what i do !!
Do you have your original? I had my original re-cored using a 2 X 45, 5/8" tube core instead of the stock 2 X 30, 1/2" tube core, more than 40% more cooing capacity and flow! Fantastic results, my 6L runs all day at +/- 170 with no shroud or extra fan, 20-30 degrees less than the old clogged core. Trick is find a good shop that still does this work, all the new rads are plastic/aluminum throw aways so re-coring is disapperaing fast and the cost of copper made this a bit more costly than a new aluminum one, but no worries about fitment. Consider it if you have the original, all they need are your tanks.
Two years ago I had it fixed but now it just has too many leaks. I would really rather spend the money on a good new one.
heres one - chec inlet & outlet positions-has side mounts too.
http://www.ebay.com/itm/NEW-Aluminum-Radiator-1967-1968-1969-Chevy-Camaro-AUTO-NO-3-ROW-GIMMICKS-/321553967770?hash=item4ade1c2a9a&vxp=mtr
others=
http://www.ebay.com/itm/221753750683?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT may be ford inlets here?
http://www.ebay.com/itm/350871272077?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT gm
others=
kookykrispy- Number of posts : 1453
Arnolds Garage wrote:I have a 69 gmc with an early 70 s 350. I've had mine worked on twice already so its time for a new one. I've read most of the previous post on the subject. The 67/70 mustang/cougar radiator that kookykrispy looks like it will work. Just wondering if anyone has used it in a second gen with a v8. Any help is appreciated.
The cougar radiator works, but only if being used in a downflow application.
If your van is a crossflow configuration, you will need to replace with a crossflow type radiator.
That being said, I imagine the aluminum cougar/mustang radiator we used on my buddy's van would cool a v8 no problem.
I think the one kookykrispy had will work. It even looks like the one I have now. It does have a fittings for a Trans cooler correct? I have a 350 turbo Trans.
Here's the one we used on my buddy's van. I want to stress that there were two different radiator set-ups offered in 2nd gen chevy vans. This will work only if you have a downflow set-up. Note that this has the correct inlet/outlets for chevy engines, and yes it does have a built in automatic trans cooler. You can see the threaded holes on the bottom tank and that's where your tranny cooler lines go.
http://www.ebay.com/itm/67-70-Mustang-Cougar-aluminum-radiator-V8-left-inlet-right-outlet-/230828903261?fits=Model%3ACougar&vxp=mtr&hash=item35be798b5d
Ordered the mustang /cougar radiator. I thank you for the info. I'll let you know how it turns out.
Vanish- Admin
- Number of posts : 5002
If it were Mine I would run an external Trans Cooler !!!! Keep some of the heat out of the Radiator !!!! Plus if that cooler in the radiator ever leaks .. your pumping water back to the trans ..... and trans fluid into the cooling system ..... ruin your trans and your radiator and Heater hoses ......
