    Tie rod/ drag link
    Vandalf
    Vandalf
    Number of posts : 20
    Registration date : 2015-03-26
    Tie rod/ drag link Empty Tie rod/ drag link
    Post by Vandalf Sat Apr 04, 2015 10:03 am
    I'm having trouble finding a replacement drag link/tie rod. Help!!
    Tie rod/ drag link Empty Re: Tie rod/ drag link
    Post by vanny Sat Apr 04, 2015 11:03 am
    Have you looked at MAC's?
    http://www.macsautoparts.com/ford_econoline/drag-link-e100.html
    I'm sure others will chime in. We have several people on this site who also have extra parts and such. Very Happy
    Vandalf
    Vandalf
    Post by Vandalf Sat Apr 04, 2015 1:02 pm
    I have. It seems the one they have for the E100 is the same I ordered from another parts site. It got here and turned out to be way too small. I might be missing something and am learning as I go though...
    cali2chitown
    cali2chitown
    Number of posts : 188
    Post by cali2chitown Sat Apr 04, 2015 2:08 pm
    Tie rods you can get from macs, rockauto etc. I got my drag link from www.carpartsdiscount.com
    and I think some people might even get them on ebay too.
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 3:37 pm
    That's where I got mine from as well. I'm not sure if they sent the wrong part or if someone already modified the steering. Any way you could post a picture of how yours looks under your van? It would be much appreciated!
    cali2chitown
    cali2chitown
    Post by cali2chitown Sun Apr 05, 2015 3:46 pm
    Sorry my truck is in a million pieces right now waiting on body work and paint. I measured it up next to the old one and it was the same. Maybe someone else will put a picture up for you.
    Post by donivan65 Sun Apr 05, 2015 4:00 pm
    I got one off a 63 if you need dimensions,,,,,,
    Tie rod/ drag link Drag_l10
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 4:25 pm
    Ok... I just went out and looked under my van. I found the drag link and it looks fine. Its in the front left correct? At the risk of sounding like an idiot, what is the bar called that is between the two tie rods? I've been told by a few people that it is called a drag link. This might be my problem...
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 4:26 pm
    https://s1303.photobucket.com/user/djdk402/media/Picture0405151819_1_zpsffhukpnn.jpg.html
    This is what I need. A replacement rod for the one that is bent.
    cali2chitown
    cali2chitown
    Post by cali2chitown Sun Apr 05, 2015 4:36 pm
    You mean the bar in between the tie rod ends? If thats what your talking about mine was bent too and I just bent it back straight and it looks great. I've only seen a few for sale and they were kind of $$$.
    Donivan might have one or know where to get one.
    Number of posts : 809
    Post by Bruce67Econoline Sun Apr 05, 2015 4:50 pm
    cali2chitown wrote:Tie rods you can get from macs, rockauto etc. I got my drag link from www.carpartsdiscount.com
    This is the part number from Car Parts Discount
    New Replacement Drag Link, 28.50", RP25781
    This is the one I bought for $175.00
    Post by donivan65 Sun Apr 05, 2015 4:51 pm
    We normally call them the center link,,,,,,,the tie rods screw into them,,,,,,,they are kind of flimsy,,,,,,not made for jack stands or floor jacks to be under,,,,,,bend it back sounds like a good idea to me,,,,,,,off the truck,,,,,,,,,,
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 4:54 pm
    how did you bend it back?? The steering is terrible with a lot of slack at the moment.
    Post by donivan65 Sun Apr 05, 2015 5:01 pm
    That bar adjusts the toe in,,,,,,you want the front of the tires pointing in,,,,,,,,not straight, as you go down the road,,,,,,,,but the steering box, drag link, tie rods, king pin and leaf spring bushings and wheel bearings need to be tight also for the truck to handle correctly,,,,,,,
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 5:05 pm
    Thanks! Ill be checking those as well. Do you know of any cross-reference bars that would fit?
    Post by donivan65 Sun Apr 05, 2015 5:10 pm
    ,,,a pipe bender will do the job,,,,,,,,or maybe a couple of 2x4's under each end as you jack  down on it from under your van bumper,,,,,,
    Tie rod/ drag link Repair16
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 5:19 pm
    Thanks. Ill try that. Cross-references?? I have yet to do the research, but any chance I could find a bar that would fit between two new tie rod ends? Or are the earlys pretty specific?
    Post by donivan65 Sun Apr 05, 2015 5:28 pm
    it don't have to be perfectly straight,,,,,,,,right now,,,,,,that bend has pulled the tie rods in,,,,,which makes the tires tilt out,,,,,,,van surely wont go straight anymore,,,,,,,,check your toe setting,,,,,,you still might be able to put the toe in back into spec by adjusting that bent bar,,,,,,,,you need to find out what you got,,,,,,,,and we come here to learn about vans,,,,,,,,and the only way is to ask questions,,,,,
    Vandalf
    Vandalf
    Post by Vandalf Sun Apr 05, 2015 5:36 pm
    Thank you for your help! I'll re-adjust the toe tomorrow and see how it goes.
      Current date/time is Sun May 19, 2024 5:18 am
