    1965 Mercury front emblem removal
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    1965 Mercury front emblem removal  Empty 1965 Mercury front emblem removal
    Post by steelrat Fri Feb 20, 2015 11:11 am
    Is the front emblem bolted on or does it come off like the door emblems using paint scraper to pry loose?
    Thanks
    Number of posts : 2086
    1965 Mercury front emblem removal  Empty Re: 1965 Mercury front emblem removal
    Post by Seth G Fri Feb 20, 2015 12:36 pm
    Don't pry it!! If it's like the Econoline ALL the emblems(doors to) have spiral threaded studs cast onto their backs with sheet metal nuts that hold the emblem on from the inside. If you look under the dash to that area on the nose you will see the nuts.
    steelrat
    steelrat
    Post by steelrat Fri Feb 20, 2015 1:25 pm
    thanks, found the 8 nuts. Arghhh what a job that was.
    Number of posts : 1747
    Post by econopoor Fri Feb 20, 2015 6:44 pm
    The front and rear are held on with trim nuts but the door emblems are held on with barrel clips. They just pop off.
      Current date/time is Sun May 19, 2024 11:26 pm
