    Engine size ?
    mcfly
    mcfly
    Number of posts : 626
    Engine size ? Empty Engine size ?
    Post by mcfly Mon Apr 06, 2009 8:49 pm
    Well the good news is my wife and kids are gone for a little vacation.The bad news is my daughter took my camera,so no pics of the 64 as of now.
    I do have a question though.
    What is the easiest why of determining the size of my motor? I look all over the motor and could not find any tags. Can you tell by the vin?
    Also anything I should know before I pull the master cylinder for a rebuild?
    mike
    Engine size ? Empty Re: Engine size ?
    Post by Guest Tue Apr 07, 2009 9:33 am
    post the VIN and if its the original engine it should be in there..
    also.. i got this from the folks at the webpage.. good place to be hanging out..
    look on the passenger side of the engine, under the exhaust manifold/just above the oil pan.. there should be some numbers in the engine block
    post them here and we can help
    Post by Guest Tue Apr 07, 2009 9:34 am
    mcfly
    mcfly
    Post by mcfly Tue Apr 07, 2009 10:16 am
    Thanks here's the vin
    E14SH445146
    I have a feeling it is 144ci
    It also has 2 belts on it
    Post by Guest Tue Apr 07, 2009 10:25 am
    http://www.lovefords.org/tech/truck/econoline_01.htm
    according to this.. yeah.. you have a 144
    mcfly
    mcfly
    Post by mcfly Tue Apr 07, 2009 10:33 am
    Thanks for the quick response
      Current date/time is Fri May 10, 2024 5:03 am
