+6
65-G10-guy
vrod64
10 posters
    65G hinge Rubber
    vrod64
    vrod64
    Number of posts : 67
    Registration date : 2013-07-20
    65G hinge Rubber Empty 65G hinge Rubber
    Post by vrod64 Mon Jan 12, 2015 6:53 pm
    Restoring and getting ready for paint. Will replace the hinge rubber .
    Am I correct that the REAR, SIDE and Front DOORS have the exterior rubber seal ?
    Steele part # 60-0659-69
    $37 dollars for 4 seals.
    Do I need 24 hinge seals ??...OUCH.
    Thought I read newer GM vans used similiar rubber gaskets ?
    Any help greatly appreciated.
    Thanks
    V
    Number of posts : 1868
    65G hinge Rubber Empty Re: 65G hinge Rubber
    Post by HandiVanMan Mon Jan 12, 2015 7:47 pm
    I am not 100% sure but I think that I read that the one's for the 3rd gens will work. Maybe someone can verify that they will?
    Post by donivan65 Mon Jan 12, 2015 9:21 pm
    front hinges are 2 3/16 wide and side and rear hinges are 2 7/16 wide also to add to your misery,,,,,
    65-G10-guy
    65-G10-guy
    Number of posts : 110
    Registration date : 2012-11-16
    Post by 65-G10-guy Tue Jan 13, 2015 12:10 am
    I bought a sample of the later ones but they were bigger on the outside and I didn't think they looked as good as originals. After the paint was done I masked the paint off and sealed the hinges with black RTV. Took some time but I was happier with the result. Good luck. Jerry
    Post by Joe Van Tue Jan 13, 2015 3:25 am
    Buy the set of 24 and cut 1/4 inch out of the centers for the front doors and use super glue to put them back together..The super glue volcanise's the rubber recommended by soft seal when I installed my windshield and rear rubbers on my 41 willys 10 years later and the glue is still holding..!!!..65G hinge Rubber 105_0810
    Number of posts : 1412
    Post by Vantasia Tue Jan 13, 2015 6:17 am
    This has been debated before....the original shop manual and old body panel repair books show a CAULK seal at the door hinges (seam sealer, Napa sells it in tubes), not a rubber gasket on 1st and 2nd? gen vans. The sealer was painted body color.  If your gaps are big enough, use the rubber seals after paint but IMHO they were not correct for a 1st gen and are too large for most of the joints.  Like 65 G10,  I simply used some paintable silicone caulk and it looks fine, white since my van is white. Some of my gaps were very thin and a rubber seal would not fit.
    Number of posts : 1293
    Post by Lazarusvan Tue Jan 13, 2015 6:23 am
    Vantasia wrote:This has been debated before....the original shop manual and old body panel repair books show a CAULK seal at the door hinges (seam sealer, Napa sells it in tubes), not a rubber gasket on 1st and 2nd? gen vans. The sealer was painted body color.  If you gaps are big enough, use the rubber seals but IMHO they were not correct for a 1st gen.  Like 65 G10,  I simply used some paintable silicone caulk and it looks fine, white since my van is white. Some of my gaps were very thin and a rubber seal would not fit.
    Vantasia, is your paint cracking around the hinges? I like the cleaner look as well, but it seems that without the rubber, the paint and caulk with crack over time.
    Post by Vantasia Tue Jan 13, 2015 6:26 am
    No cracking, but the caulk gets soiled, I wipe it clean with some cleaner every now and then, but it seals out water for sure! Again, if I was painting the van, I would use seam sealer before painting like the factory, but afterwards, use RTV or any old caulk.
    Number of posts : 1778
    Post by m1dadio Tue Jan 13, 2015 5:54 pm
    There are options (like everthing else on these vans) I did the use body caulking and the 3rd gen stick on ones. I didn't really like them.
    So I just bought enough for 24. I didn't look and realise that the fronts where smaller. Bummer.
    Oh well I will have extras to sell.
    Because Clarks Corvair has the hinge gaskets in two sizes. I asked and they sent me an email with the measurments. this is for the Corvan.
    The measurements on the inner hold for C9945 $8.35 each side door hinge grommet is 2 3/8" X 1/4"
    The C9946 $7.95 each rear door hinge measures 2 1/2" X 1/4"
    Clarks Corvair Parts Inc
    400 Mohawk Trail
    Shelburne Falls, MA 01370
    413-625-9776
    413-625-8498 fax
    www.corvair.com
    I measure the hinges to be 2.25" and 2.5" since the front door body sheet metal is on an angle i figure the 2.25" one should pinch in and work.
    M1D
    The hinges on the Suburmen barn doors are 2.5" also
    Post by Lazarusvan Tue Jan 13, 2015 6:26 pm
    Just came across this photo I took at the Charlotte Auto Fair last April.
    Not sure what was used.
    65G hinge Rubber Unname13
    HurricaneBilly
    HurricaneBilly
    Number of posts : 25
    Registration date : 2014-11-25
    Post by HurricaneBilly Tue Jan 13, 2015 6:47 pm
    I plan on using seam sealer . you can buy it in different colors as well . I will use black.
    Post by Vantasia Wed Jan 14, 2015 5:51 am
    HurricaneBilly wrote:I plan on using seam sealer . you can buy it in different colors as well . I will use black.
    Again, if you are pre-paint, that's the way to go and it takes paint well. Post paint, its a little messy, doesn't wipe off like caulk, very tacky, more like construction adhesive.
    Post by Twinpilot001 Wed Jan 14, 2015 9:02 am
    Thats black RTV above!! Evil or Very Mad
    Guess someone could put that stuff from the inside on hinge also?? Personally =?? i just dont like the look on that - my 3rd gen van has the factory seals on it & can be made to work nicely on earlys!! cheers
      Current date/time is Thu May 02, 2024 3:12 pm
