headlight bezel
steelrat- Number of posts : 116
Registration date : 2014-11-25
headlight bezel
Big W- Number of posts : 3282
Registration date : 2011-01-14
Re: headlight bezel
I just went outside and looked at mine, and I don't have any extra holes. The two small screws that show are only for the bug screen that is separate from the bezel. I'm guessing that screws for the bezel were stripped out and someone added these larger ones two keep the bezel from falling off.
Re: headlight bezel
OK...lol...just went back out and looked at my 67 which has no bezels on it, but still has bug screens. Bug screens are held on by to brackets, top and bottom, behind the bezel. The 2 small screws seem to have something to do with the air box that's screwed to the front sheet metal. Previous owner may have just used a bigger screw to help hold that box in place. Camera battery on the charger. If no one posts a pic I will shortly to show bug screen brackets.
Re: headlight bezel
Re: headlight bezel
It's the vent box or heater box attaching screws
Re: headlight bezel
Ok, thanks. I will see what is on the inside. Wondering why holes vacant if supporting a heater box..?
Re: headlight bezel
Re: headlight bezel
I didn't see the extra hole until now but the screws were probably stripped and someone drilled them out and attached with other screws. An interesting side note, the vent box screws and heater box screws are different. I forget which one but one of them uses fine thread screws.
Re: headlight bezel
If both sides have that big hole, I would guess that someone had fog lights mounted there.
