    How best to pull out old flooring.
    steelrat
    steelrat
    Number of posts : 116
    Registration date : 2014-11-24
    How best to pull out old flooring. Empty How best to pull out old flooring.
    Post by steelrat Mon Dec 08, 2014 3:39 pm
    Hi All,
    Here are some pics of the old floor in the Mercury.
    After removing the cabinets/benches do I just pry/scrape it up?
    Looks like there will be a lot of gummy black material under it. Do I remove this, or if fairly consistent lay the vinyl plank over it? Thanks.
    How best to pull out old flooring. Driver10
    url=https://servimg.com/view/19067990/56]How best to pull out old flooring. Passen10[/url]
    How best to pull out old flooring. In-fro10
    How best to pull out old flooring. By-dog10
    Number of posts : 2374
    Registration date : 2014-04-15
    How best to pull out old flooring. Empty Re: How best to pull out old flooring.
    Post by weirdbeard Mon Dec 08, 2014 3:58 pm
    If you heat it up that helps. Just a heads up the tile is most likely and the black mastic is Asbestos so dont grind, sand, etc to make it friable and airborn.
    steelrat
    steelrat
    Post by steelrat Mon Dec 08, 2014 4:02 pm
    Shocked wow, thanks for telling me that. I guess I should try remove it all then?
    diamond dave
    diamond dave
    Number of posts : 565
    Post by diamond dave Mon Dec 08, 2014 4:11 pm
    i'd pull all the subflooring out also. that way you can start fresh and inspect the steel floor before you cover it back up again.
    steelrat
    steelrat
    How best to pull out old flooring. Empty It begiins..
    Post by steelrat Wed Dec 10, 2014 5:51 pm
    Pulled bench seat/bed cabinets out. Will determine how well the propane heater and burners work to make decision on that cabinets future. Some of the tiles came up real easy when removing cabinets. Subfloor will be removed as well.
    The paneling needs to be replaced. very brittle where cabinets were.
    Sorry for poor quality pictures.
    How best to pull out old flooring. Img_2010
    url=https://servimg.com/view/19067990/61]How best to pull out old flooring. Img_2011[/url]
    url=https://servimg.com/view/19067990/62]How best to pull out old flooring. Img_2012[/url]
    url=https://servimg.com/view/19067990/64]How best to pull out old flooring. Img_2014[/url]
      Current date/time is Sun Apr 28, 2024 11:37 am
