Carl
AZ SuperVan
    Which Econolines came with the Ammeter and Oil Pressure Gauges?
    AZ SuperVan
    AZ SuperVan
    Number of posts : 219
    Registration date : 2013-09-12
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Empty Which Econolines came with the Ammeter and Oil Pressure Gauges?
    Post by AZ SuperVan Tue Nov 25, 2014 3:35 pm
    I have seen pictures of a dash panel with gauges instead of idiot lights in the bottom two locations. Was this an option or did they do this on Heavy Duty or ????
    I would prefer to have gauges, but both my '65 and '66 vans have idiot lights. Is this is a simple conversion?
    Carl
    Number of posts : 143
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Empty Idiot light to gauge conversio
    Post by Carl Tue Nov 25, 2014 10:10 pm
    I would say not too hard to do. The wiring diagram for the 67 Econoline with four gaugee: www.vintage-vans.com/67fordwiring6.html -from that diagram, you need to add a wire and run it thru the ammeter, and for the oil pressure gauge, buy an oil pressure sending unit and add a wire from the constant voltage unit (about 6 volts) to that gauge
    Carl
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Empty Ammeter and oil pressure Gauges
    Post by Carl Tue Nov 25, 2014 11:10 pm
    My Econoline is a 67 and I think that the only year they had those gauges. I have an extra 4 gauge cluster I bought on ebay years ago, if you are interested? The speedometer not good but has the 4 gauges FUEL TEMP ALT OIL $25
    CraigK
    CraigK
    Number of posts : 141
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Empty Re: Which Econolines came with the Ammeter and Oil Pressure Gauges?
    Post by CraigK Wed Nov 26, 2014 3:53 am
    Carl, That is a great price. Bill you should jump at that.
    I just converted mine. Wasnt hard to do just take your time.
    I now have 4 new gauges in there and bought a paint pen and did the speedo pointer.
    I havent completed the wiring yet as its all out of the van and I want to rework the wire harness.
    Craig
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0810
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0811
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0812
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0813
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0814
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_1010
    Which Econolines came with the Ammeter and Oil Pressure Gauges? Img_0815
    Number of posts : 864
    Post by Casimier Wed Nov 26, 2014 5:31 am
    If you use Presstype White Letters it is easy to put the Fuel, Oil, Temp and Amps back on the black panel.
    Most art stores carry these.
    I did mine and it was very easy.
    Jim in NJ aka Casimier
    CraigK
    CraigK
    Post by CraigK Wed Nov 26, 2014 6:04 am
    Thanks Jim. I havent looked for the letters yet.
    AZ SuperVan
    AZ SuperVan
    Post by AZ SuperVan Wed Nov 26, 2014 7:43 am
    Offer accepted! Thanks!
    Vancy65
    Vancy65
    Number of posts : 47
    Registration date : 2014-03-10
    Post by Vancy65 Wed Nov 26, 2014 11:58 am
    My '65 heavy duty has all 4 gauges and the wiring looks old and original.
    Number of posts : 2011
    Post by Barnabas Wed Nov 26, 2014 6:45 pm
    A lot of the Ford trucks of the same vintage had the gauges.
      Current date/time is Sat Apr 27, 2024 11:14 pm
