just need to ask ?.i am wanting to put chromes/ slots/ sawblades etc on my 66 gmc handi. just wondering what kind of modern day auto would go on it. any info ty . do not want to pay a lot for new
wheels on 66
Re: wheels on 66
Almost anything with the 5x4 3/4 bolt pattern, What you do have to watch for is the backspacing, gotta keep enough distance to turn and clear all the suspension.
DanTheVanMan- Commissioner
- Number of posts : 7900
Re: wheels on 66
Phillip,
Like Digz said Just about anything with a chevy bolt pattern. 14's or 15's will work. Just picked up some Iroc/ Z28 mags for $50. Just because I couldn't pass them up for that price. Good to have some cool spares!!!!
Do a search on eBay for Chevy 5x 3/4 wheels, you'll get pages and pages... Just becareful on eBay. I got burned on some slotted mags (2 were warped)...
Dan
Dan
Re: wheels on 66
Re: wheels on 66
Re: wheels on 66
Re: wheels on 66
Gotta say Heavy, that's one sharp lookin Van!!!
Re: wheels on 66
So, what's the max back spacing for 1st Gen's? Also, while I'm on a sort of related topic...1st and 2nd Gen wheels should be the same size and have the same clearance specs, right?
Sorry for the questions...just trying to start learning a little about the van I'm about to bring home....
Re: wheels on 66
3 and 3/4" is quite common on say a 15x7 aftermarket wheel and would be quite a good fit on the front of a 1st gen, the rims I just got are 4" backspaceand I might have to change the bump stops so the tires dont rub on the suspension ,but Im not sure of that yet. On the rear I wouldn't be suprised if you get get away with an 8'backspace but dont quote me on that . . you can go the otherway to far also, to little like a deep dish with 2and 3/8" backspace on a 15x7, this throws your turning radius into the sheet metal on the front of the wheel arch. I dont know if this helped much but its the stuff you have watch out for. the back space on the 15x10s for the rear is also 4" and thats no problem. I think the biggest factor is overall tire diameter, seems like a alot of stock 14 inch tires run about 26-27"s OD , to keep that diameter in a 15" tire you almost have to run a 60 series, but each manufactorer is a little different it seems.
