    vin numbers
    vin numbers Empty vin numbers
    Post by Guest Tue Mar 24, 2009 7:13 pm
    i have found a 67 chevy no door that i can buy for a good price....the problem is.....i thought the vin plate was in the door jam, under the latch mechanism. what IS there.... are two rivets, about 3" apart, but no plate. isn't this where it is supposed to be? artwerkz (formerly paintr01)
    vin numbers Empty Re: vin numbers
    Post by donivan65 Tue Mar 24, 2009 7:25 pm
    Look on the crossmember in front of the gas tank,,,,,,right below where the fuel hose goes through,,,,,,,,also it would be on that crossmember in back of the tank,,,,,
    vin numbers Repair19
    Post by Guest Wed Mar 25, 2009 10:25 am
    I have a clean title and I.D. tag for a 1/2 ton 6-cylinder Chevy van that I scrapped out years ago. Let me know if you're interested.
    Post by donivan65 Wed Mar 25, 2009 11:26 pm
    The VIN plate WAS on those 2 rivets above the latch on the rear drivers side door post,,,,,,,,And now it could be on someones elses van,,,,,,so,,,,get the Vin off the crossmember, check the title and with DMV to see if someone has that van currently registered,,,,,,,
    Post by Guest Thu Mar 26, 2009 2:48 pm
    thanks guys..........again! what a great group !
    Post by Guest Thu Mar 26, 2009 2:50 pm
    oh...and KC...if i need that title, i'll let you know....thanks a million...derek
    Post by donivan65 Fri Mar 27, 2009 7:00 pm
    Here is where a 1970 VIN Plate is,,,,,,,,
    vin numbers Harry_10
    Post by Guest Sat Mar 28, 2009 6:29 pm
    ok.....i don'know if i looked there, but it seems it would have jumped out at me, as hard as i was searching.....and again...those rivets...but i'll double check....thanks
      Current date/time is Tue May 07, 2024 11:44 pm
