    1963 master cylinder rebuild
    1963 master cylinder rebuild Empty 1963 master cylinder rebuild
    Post by Guest Sun Mar 22, 2009 5:42 am
    Has anyone rebuilt their master cylinder and had the problem of the piston being to tight to fit into the the cylinder bore? If so what was the solution. pig
    Number of posts : 987
    1963 master cylinder rebuild Empty Re: 1963 master cylinder rebuild
    Post by RipVanArkie Sun Mar 22, 2009 7:02 am
    If the piston came in the kit, it might be the wrong kit...
    Later,
    Rip
    Post by Guest Sun Mar 22, 2009 7:42 am
    Thanks for responding Rip. I believe its the right kit everything is the same size. The rubber seal around the piston just seems pretty tight. I have it soaking in brake fluid maybe it will soften it up.
    Post by donivan65 Sun Mar 22, 2009 11:23 am
    1963 master cylinder rebuild Ford_m10
    Post by Guest Sun Mar 22, 2009 8:06 pm
    Thats the kit I got the rubber around the piston is tight to try and get it in the bore. Once it gets to the outer flange of the rubber seal it stops going in. is thier a tool i need maybe?
    Post by donivan65 Sun Mar 22, 2009 9:56 pm
    So the spring and inner cup go in and so does the piston until the seal on it gets stuck like in the snap ring groove? I would be sure that there is no lip or edge sticking up and clean it up with some emory cloth. Then lubricate that seal with assembly lube or brake fluid and tuck it into the bore with a small screwdriver,,,,,,
    Post by Guest Mon Mar 23, 2009 9:30 am
    That's a strange looking master cylinder. Did all the early Econos use that?
    Post by Guest Mon Mar 23, 2009 1:21 pm
    Thanks Donivan, I'll give that a try. I thought maybe there was a tool to get that flange pushed back. Yeah everything fits good except that rubber seal around the piston.
    Number of posts : 2067
    Post by sasktrini Mon Mar 23, 2009 3:04 pm
    Nate, that's the single-manifold one used till 66.
    Post by donivan65 Mon Mar 23, 2009 3:11 pm
    I guess a real thin feeler gauge would help the seal get over the rough spots also,,,,,,,
    primaldesigns
    primaldesigns
    Number of posts : 71
    Registration date : 2009-01-11
    Post by primaldesigns Wed Nov 18, 2009 5:11 pm
    Has anyone bought a master cylinder from RockAuto.com?
    I have a 1963 Falcon Station bus. I checked RockAuto and they do not list master cylinders for 1963 Econoline or Station bus. But they do list master cylinders for 1963 Club Wagon and Club Wagon Deluxe. It shows pics of the master cylinders and they look the same as the one that I have. Can anyone tell me if they are indeed the same and why the price difference of $81 for one and $100 for the other?
    Number of posts : 2198
    Post by EconoUSAparts Wed Nov 18, 2009 8:56 pm
    Now would be the time to upgrade to the dual master conversion from D and D Brakes for added safety. Its the next best thing to a factory dual master and being that its a remote fill is a plus.
      Current date/time is Fri May 17, 2024 1:37 am
