    need help with 6cyl part
    Donn
    Donn
    Number of posts : 692
    need help with 6cyl part Empty need help with 6cyl part
    Post by Donn Fri May 09, 2014 1:34 pm
    Just bought a '61 with a 6cyl motor. I need a crankcase outlet tube if anyone has one they would sell.
    Or has anyone plugged this hole with some sort of breather that works?
    Thanks
    donn
    need help with 6cyl part Get-at20
    Number of posts : 394
    need help with 6cyl part Empty Re: need help with 6cyl part
    Post by dan nachel Fri May 09, 2014 1:39 pm
    I believe you can plug that hole if you put a PCV valve in the valve cover. Check on the "inline 6" site or ford.
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Fri May 09, 2014 2:40 pm
    Donn,
    You can plug it with a freeze plug and switch to a PCV valve. You will have to get a 65 up valve cover with a front oil fill cap with the PV valve hole and a carb spacer with a vacuum outlet or plug to add one. You can also use a breather from a 2.3 liter Pinto motor, they press right in.
    Fred
    Donn
    Donn
    Post by Donn Sat May 10, 2014 7:13 am
    Thanks Fred going to auto store today and see if they have one
    Post by Guest Mon May 12, 2014 10:08 am
    Don, I may have the valve cover your looking for. I'll check.
    Donn
    Donn
    Post by Donn Tue May 13, 2014 4:42 pm
    Vintage Metal wrote:Don, I may have the valve cover your looking for.  I'll check.
    Thank you but I think I solved the problem. Ended up getting a rubber stopper with a hole through the center of it and shaved it to fit. So far its working.
      Current date/time is Sun May 19, 2024 10:30 pm
