    Ran tank dry.
    66mnecotruck
    66mnecotruck
    Number of posts : 327
    Registration date : 2014-02-15
    Ran tank dry. Empty Ran tank dry.
    Post by 66mnecotruck Mon May 05, 2014 8:57 pm
    I had my 300 running and accidently ran the tank dry. Now it's no joy. Could I have sucked water into the system? I did have a new inline fuel filter on.
    Number of posts : 2086
    Ran tank dry. Empty Re: Ran tank dry.
    Post by Seth G Mon May 05, 2014 9:52 pm
    Shouldn't be a big problem, sometimes getting gas back to the carb can be a pain but it will come. If you're concerned you could replace the filter after you get it going again.
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Post by 66ThunderVan Tue May 06, 2014 8:44 am
    No danger, it's not like a diesel or newer EFI system. Just put some gas in the tank and remove the air cleaner and use some starter fluid or carefully pour a little gas down the carb and get it to fire up. Sometimes you will have to repeat the process a few times to get the pump to get gas up to the carb. Warning, keep your face clear of the engine while cranking the engine as a back fire will burn you.
      Current date/time is Sun May 19, 2024 2:58 pm
