    Ball park valve adjustments
    Lance0538
    Lance0538
    Number of posts : 24
    Registration date : 2013-04-19
    Ball park valve adjustments  Empty Ball park valve adjustments
    Post by Lance0538 Sun Apr 27, 2014 6:07 am
    Alright so I just got my engine back from getting rebuilt.(144) Can anyone help me with an initial valve adjustment. I was trying it the way off classicinlines.com. basically it said rotate the crankshaft until the exhaust valve starts to open then adjust that intake valve by tightening until the pushrod wont spin, then backing it off a quarter turn. Pretty much the same when the intake goes down and is almost all the way back up, adjust the exhaust.
    I have used this method before on the engine and it worked fine but now i can tighten the nut all the way down and the pushrod will still spin. Is there a better way for an initial valve adjustment? Hope I made sense. Thank.
    Number of posts : 1747
    Ball park valve adjustments  Empty Re: Ball park valve adjustments
    Post by econopoor Sun Apr 27, 2014 5:52 pm
    The 144 should have solid lifters. That adjustment only works with hydraulic lifters. You need to set these with a feeler gauge.
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Post by 66ThunderVan Sun Apr 27, 2014 9:01 pm
    .018 hot, int and ex.
    Lance0538
    Lance0538
    Post by Lance0538 Mon Apr 28, 2014 3:09 am
    So will .018 be fine cold until i can get it up to operating temp, since its a rebuild.
    Post by Twinpilot001 Mon Apr 28, 2014 3:11 am
    likely will be fine -just get to temp & readjust all!! cheers
    66ThunderVan
    66ThunderVan
    Post by 66ThunderVan Mon Apr 28, 2014 5:39 am
    Like Twin said, just set at .018 get it running and warm then readjust. Usually the first adjustment will have one or two valves that make noise so you will want to warm it up and get the clatter out. Please understand that solid cams are noisy by design so do not be tempted to set lash tighter than .017 or.018 or you will burn the valves. Happy Vanning,
    Chris
    Lance0538
    Lance0538
    Post by Lance0538 Mon Apr 28, 2014 9:24 am
    Thanks for all the replies. Hope to turn the key by Wednesday. Im getting pretty nervous. Cant imagine how im going to feel two seconds before doing it. Neutral
    Post by Twinpilot001 Mon Apr 28, 2014 9:27 am
    Just have a 6 pack - bury ur head in the sand-& do it!!!!!!!!!!!!!!!!!! lol! lol! lol! cheers
    66mnecotruck
    66mnecotruck
    Number of posts : 327
    Registration date : 2014-02-15
    Post by 66mnecotruck Mon Apr 28, 2014 10:21 am
    Twinpilot001 wrote:Just have a 6 pack - bury ur head in the sand-& do it!!!!!!!!!!!!!!!!!! lol! lol! lol! cheers
    Ha cheers  Two seconds after..., and it doesn't start....have another six pac. Laughing
    Lance0538
    Lance0538
    Post by Lance0538 Mon Apr 28, 2014 11:53 am
    So i need a twelve pack then. I might have a bottle of whiskey on stand by incase it explodes. Haha
    Post by Twinpilot001 Mon Apr 28, 2014 11:54 am
    Said by an =EXPERIENCED =Econo mechanic!!!!!!!!!!!!!!!! affraid cheers cheers cheers lol! lol! lol! lol!
      Current date/time is Fri May 17, 2024 4:56 am
