    61 door hinge ?
    Cdcracing
    Cdcracing
    Number of posts : 245
    61 door hinge ?  Empty 61 door hinge ?
    Post by Cdcracing Sat Apr 26, 2014 8:18 am
    I have a 61 ford econo and the rear door hinge needs to be replaced and also the front door hinge is bent . It's not the pins but the hinge . What is the best way to remove them ? I see one side is riveted . When you replace them do you just use bolts where the rivets use to be ? What is the best way ? Thanks
    Number of posts : 655
    61 door hinge ?  Empty Re: 61 door hinge ?
    Post by 61econoline Sat Apr 26, 2014 8:44 pm
    Yes I had to do that on a 61 Pick-up once not a fun job but it is possible,it helps to have a second set of hands when installing the nuts on the bolts on the lower hinge.
    Cdcracing
    Cdcracing
    Post by Cdcracing Sun Apr 27, 2014 10:45 am
    Thanks Charlie
    NASH Eco
    NASH Eco
    Number of posts : 6
    Registration date : 2014-10-14
    Post by NASH Eco Tue Oct 14, 2014 7:56 pm
    Hey guys, this topic seemed to be the closest to the issue that I am currently having. I just recently acquired a '66 Eco van and couldn't be more excited about it. First time owning one. Although I'm having some hinge issues. They all hinge open and close one door in particular looks like it had a pretty good impact that has caused some significant rust over the years as well as overall alignment.
    I've searched the internet for replacement hinges with no luck, and haven't been able to find any donors either. Any suggestions on what I could turn to next? Haven't checked any pull-a-part yards around town yet but can't imagine there being a bounty of these things sitting around. Any ideas?
    61 door hinge ?  Empty hinges
    Post by 61econoline Tue Oct 14, 2014 9:25 pm
    pretty sure I have a set of nos hinges in my garage. I will look tomorrow and get back to you
    NASH Eco
    NASH Eco
    Number of posts : 6
    Post by NASH Eco Tue Oct 14, 2014 9:49 pm
    Fantastic! Thank you.
    Number of posts : 2198
    Post by EconoUSAparts Thu Oct 16, 2014 4:57 pm
    I can cut good door hinges off damaged doors that I save just for that purpose.. I might have what you need.
    Post by 61econoline Thu Oct 16, 2014 5:44 pm
    I have one set I bought from green sales awhile back. pm me if you want them.
    NASH Eco
    NASH Eco
    Number of posts : 6
    Post by NASH Eco Fri Oct 17, 2014 2:31 pm
    Thank you both for the responses. Tim I'll send you a PM to see if maybe you have some other parts I am looking for!
      Current date/time is Sat Apr 27, 2024 12:31 am
