by dulcimerbob Thu Apr 24, 2014 3:01 pm
Don't have any pics . The long fuzzy strip goes in the metal channel and is held in place with clips so when you roll the window down it stays in place . I used the original strip which the glass guy installed after the window was in place. After the strip was installed , since there were no clips , it would not stay in place . I bought some #8 x 3/8 bugle head sheet metal screws drilled a small pilot hole in the strip and put in a screw in 4 places in the top of the door and 4 in the left side of the strip. This is done with window down . Works fine as the shape of the screw flushes with the strip and no glass is touched. Hope this helps.
