    install air bags
    Number of posts : 2036
    install air bags Empty install air bags
    Post by dodge man Tue Apr 15, 2014 2:51 pm
    wanting some feed back. I want to lower my van to get in easier and raise it back up, not slam it, just drop it about 4 or 5 inches and raise it back up to travel, I don't want to add 4 bar links or weld in anything, I was wandering if I removed all the spring leafs and just used the main leaf if I put bags on top the axles between axle and frame, would it work, or would the main leaf brake the first time you let the air out, I know they make bags that would fit in that space, any ideas???
    john
    Number of posts : 2011
    install air bags Empty Re: install air bags
    Post by Barnabas Tue Apr 15, 2014 4:40 pm
    Some folks have bagged their Econolines and some have moved the axles over the springs. I am sure someone has done the same to a Dodge. Have you searched here?
    Post by dodge man Tue Apr 15, 2014 5:34 pm
    not yet I haven't, but I never ran in to any one on here bagging a dodge i'll search
    diamond dave
    diamond dave
    Number of posts : 565
    Post by diamond dave Tue Apr 15, 2014 8:38 pm
    it's called an air over leaf setup. you might leave the two longest springs in, and then put the bags on. I have a few friends with the setup on their hot rods. haven't seen it used on the front suspension with leafs though. I think it would be too unstable and squirrely up front.
    Post by dodge man Wed Apr 16, 2014 7:00 am
    thanks man, that might be best using the 2 long leafs, i'll keep checking for a way to do it,
    john
      Current date/time is Fri Apr 26, 2024 1:21 pm
