    questions about a 1968 Dodge A-108...
    Mike Blais
    Mike Blais
    Number of posts : 11
    Registration date : 2014-03-07
    questions about a 1968 Dodge A-108... Empty questions about a 1968 Dodge A-108...
    Post by Mike Blais Fri Mar 07, 2014 10:34 am
    Very Happy The reverse lights on a 1968 Sportsman, is the contact in the shifter? Ball and Trunnion, convert it or grease and cover? Front breaks, convert to disk or leave the drums? Thanks, Mike
    BILL Carson
    BILL Carson
    Number of posts : 171
    Registration date : 2011-05-02
    questions about a 1968 Dodge A-108... Empty Re: questions about a 1968 Dodge A-108...
    Post by BILL Carson Fri Mar 07, 2014 11:06 am
    disk brakes are the way to go .there are manyt vanners on the site that have done disk .i have them an i do love them .your not all over thr road when you have to make a fast stop.it's great
    Number of posts : 8731
    Post by dix Fri Mar 07, 2014 12:43 pm
    YES, YES, AND YES ON THE DISC BRAKES,    There  is some parts aval on the trunion but I took my shaft to a driveshaft shop and  had mine converted,   and i beleive on the automatic tranny the nutural saftey switch is the contact for the reverse lights. there is only one wire at the shifter , For the light,
    Mike Blais
    Mike Blais
    Post by Mike Blais Fri Mar 07, 2014 12:50 pm
    Hmmm.. The neutral safety switch could be a problem.. The motors a 340 from a 1970 Cuda.. I'll have to figure this one out.. Were the calipers a problem for your front tires post conversion? Just get the flush side walls.. What seems to be the best conversion fit?
    BILL Carson
    BILL Carson
    Post by BILL Carson Fri Mar 07, 2014 1:17 pm
    dave your an angel.dave will stear you the right  he walked me through the disk brakes an thay worked out great
    Post by dix Fri Mar 07, 2014 2:23 pm
    Bil Carson Scottie and I are not running the typical bolt on disc brake conversion set up ours are for a lack of a better word a self enginered setup, but requires a trip to a junk yard and some machine shop work, If this is not avail I'd say go with the scarbird set up that will just bolt right up , I'd say we have about 6 or move members who went that route, As far as the factory /stock rims they will not clear the calipers , I did try the mopar rallye wheels 14" and 15 " and they did not fit either. I am running the cragar s/s wheels 14" and they do work, so what you need is a newer wheel that was intended to work withe the disc brake caliper set up, most aftermarket wheels should work,... Also you will be changing the master clyinder (mc) on this upgrade.Dodge Man is the most recent member to do the scarbird disc brake conversion, Regardless we can walk you thru what set up you choose .
    Mike Blais
    Mike Blais
    Post by Mike Blais Fri Mar 07, 2014 5:23 pm
    Thanks guys! I'll be cleaning, preping and sealing my gas tank tomorrow.. POR-15 seemed like the best from everyone I'd talked to.. Using the marine cleaner, then metal prep, then sealer..I think there were 3 different tanks for that year van.. My sending unit is I. The rear of the tank.. Not easy to find one in good condition.. This one was pretty dirty inside but otherwise ok..
    Mike Blais
    Mike Blais
    Post by Mike Blais Fri Mar 07, 2014 5:26 pm
    The scar bird set up.. Get that through Summit racing, Jegs,??
    Mike Blais
    Mike Blais
    Post by Mike Blais Fri Mar 07, 2014 5:34 pm
    Googled it..I've got some measurements to take..either the a body with ore drilled 5 on 4 or the 9" drums..
    BoneMan
    BoneMan
    Number of posts : 169
    Registration date : 2011-06-23
    Post by BoneMan Fri Mar 07, 2014 5:41 pm
    Post by dix Fri Mar 07, 2014 7:00 pm
    you should need your axle rating either 2,200 or 2,500lb. and i beleive it's 10" or 11" not 9"
    2,200 should be 10"
    2,500 should be 11"
    Mike Blais
    Mike Blais
    Post by Mike Blais Sat Mar 08, 2014 8:12 am
    I'll check it out. The master cylinder needs to be changed out too.. Is there a recommendation?
    Post by dix Sat Mar 08, 2014 9:14 am
    the wheel /leaf spring ratings are on your vin plate. the drum bolt spacing  is ( 5 on 4 1/2  )
    NOT  5 ON 4.  THE MC NEEDED IS FROM A 1970-THRU 1974 DODGE --B VAN , it had front disc brakes and drums in the rear, so it had front disc but did not have a booster so it did not have power brakes.
    I hope that makes since, there is some sheet metal cutting involved to make the mc in place.
    Mike Blais
    Mike Blais
    Post by Mike Blais Sat Mar 08, 2014 10:46 am
    Thanks guys! I'll keep you posted on my progress!
      Current date/time is Sat May 11, 2024 8:27 pm
