    Engine box insulation / noise
    rustytoolss
    rustytoolss
    Number of posts : 624
    Engine box insulation / noise Empty Engine box insulation / noise
    Post by rustytoolss Tue Feb 25, 2014 9:48 am
    I've been planning to remove the insulation inside my engine box, and replace it with a 2 sided foil that has a compressed plastic type material. I think its called cool mat or something ( it can handle engine bay temp) about 1/4" thick.
    I was wondering if I remove the original insulation an install the new stuff. Will I get a lot more engine noise ?
    I'm sure the heat insulation will be better with the new stuff. As the covering of the old insulation is in bad condition.
    Just unsure of engine box noise.
    Engine box insulation / noise Empty Re: Engine box insulation / noise
    Post by Guest Tue Feb 25, 2014 10:51 am
    I used a replacement that was similar to the original material. It did help with noise and was a huge heat barrier.
    http://www.summitracing.com/parts/the-13590/overview/
    Something about using that plastic insulator in the engine doesn't seem right to me.
    I did use that stuff in my interior walls though!
    rustytoolss
    rustytoolss
    Post by rustytoolss Tue Feb 25, 2014 11:25 am
    I'm not worried about it causing a fire. I watched a video of it with a fire test. The worst thing that happened was minor charred edge after long exposure to intense open flame. I'm king of thinking of just adding the new stuff over top of the stock insulation= doubling the insulation and noise value.
    Number of posts : 2036
    Post by dodge man Tue Feb 25, 2014 11:33 am
    I used dynomat and 1/2 thick fiberglass over top and after the engine gets hot the dog box is still cold, and all you can hear is the exhaust out the window, no engine noise inside
    rustytoolss
    rustytoolss
    Post by rustytoolss Tue Feb 25, 2014 11:59 am
    dodge man wrote:I used dynomat and 1/2 thick fiberglass over top and after the engine gets hot the dog box is still cold, and all you can hear is the exhaust out the window, no e
    ngine noise inside
    So you used both, on all surfaces? or just both on the lid ? Did you insulate the front radiator air inlet section of the box ?
    Post by dodge man Tue Feb 25, 2014 1:01 pm
    yes I used dynamat even in front of the radiator, what I had left over I used on the front floor, I bought the 135.00 pack, and I covered everything with one sided aluminum 1/2'' fiberglass, it worked out great,
    Post by dodge man Tue Feb 25, 2014 1:10 pm
    Post by dodge man Tue Feb 25, 2014 1:34 pm
    Engine box insulation / noise Sam_0810
    Number of posts : 956
    Post by slowflapper Wed Feb 26, 2014 9:59 am
    search the forum here, I've posted contact info for the guy I bought my kit from a few times. Its a great kit and very quiet, iirc, quiet ride also sells a kit.
    Engine box insulation / noise IMG00433-20100314-1159
    eta: Dodge Man, get some foil HVAC tape from home depot and tape your edges down so the matting doesn't get wet, it will last years longer if you do so.
    Post by dodge man Wed Feb 26, 2014 10:56 am
    thanks slowflapper, i'll do that I never thought about it great idea,
      Current date/time is Sun May 19, 2024 3:06 am
