I am going to be doing the king pins and bushing on my 67 A108 and I was wondering if anyone could explain the difference between the two different Raybestos sets that I see from RockAuto?
Raybestos part #5301059 states that it is ball bearing & contains washer bearing and metal bushing ($43)
Raybestos part #5301044 states that it is bimetal bushing & contains ball bearing and metal bushing. ($53)
What I want to know is what is the better quality set? the one that says ball bearing contains washer bearing or the one that says bimetal bushing contains ball bearing.
They both are listed for the 67 A108 with the 2500lb axle. I am not very familiar with king pin sets other then the fact that I know I want the metal bushings as opposed to nylon. Any help in explanation / diff. between the two sets would be greatly appreciated. Thanks, Brian
