Time to weigh in on which one is more useful than the other. Eastwood has soda and sand blasters which one is the better of the 2 to get for doing our vans????
Soda blaster vs. sand blaster
Re: Soda blaster vs. sand blaster
If you have the cash soda is better for the fact that it won't warp body panels
G-Man wrote:If you have the cash soda is better for the fact that it won't warp body panels
Yup......soda.
Not that big a price difference 100. bucks??? But that answers the question, I got enough problems without warping panels
soda doesn't heat the panels like sand, but I'm sure soda is more per bag
Within a 3. bucks of each other for 60 grit alum oxide, soda is a 20% blend of alum oxide. Price for 1-3 50lb bags.
how about walnut shelles , any one try that?
I have heard of that, never seen it used. There also dry-ice blasting
never heard of the dry ice., i want to try walnut shelles, i investigated them a long time ago. i have an old farmall needing paint ill have to search for some crushed shells and try them. course we all use black beauty up here. i dont blast sheet metal i just take a d.a. to it
DanTheVanMan- Commissioner
- Number of posts : 7900
Soda for the body, Sand for the under carriage. Walnut shells are great and polishes any surface but not really good for removing paint. Would work really great for removing crud from that Farm All…
Around here sand is like 8$ a bag and from what I have done it works fine anyplace there is a body line or seam to keep things stiff, many layers of paint and I would recommend chemical stripping on the flats, If I am remembering correctly soda blasting gives you more time to get the metal protected because it doesnt raise the surface like sand does and doesnt soda require a slightly different set up for the pot than sand?
digz.... your right, it's a little different setup and I read somewhere about the extended time also. Like benwah I'm probably going to do most of it with a DA.
Dans right on Walnut shells--I was on a Navy Hydro foil in the 80's.... It was built of aircraft Aluminium.....The ship yard used walnut sheels on the hull in the yards....took off the paint, but actually polished the surface when it came off.
Ill probablyuse soda on the 65....Dont wnat to heat it up any worse than its been cooked already on the passenger side....
