+5
gkpost
sailer
9 posters
    body style - windows and a panel in one
    sailer
    sailer
    Number of posts : 2
    Registration date : 2014-01-16
    body style - windows and a panel in one Empty body style - windows and a panel in one
    Post by sailer Thu Jan 16, 2014 11:31 am
    New to the site, new to my old van (almost, still negotiating)
    looking at buying a 69 chevy but curious.... never seen a panel van (drivers side) and a window van (passenger side) in one vehicle.
    I like the look. Is it common? what's the body style called?
    Number of posts : 1747
    body style - windows and a panel in one Empty Re: body style - windows and a panel in one
    Post by econopoor Thu Jan 16, 2014 11:49 am
    they are called display vans. The reasoning behind them was to provide a place for storage bins on the drivers side and visibility out the right side windows. Very popular with electricians and plumbers or anyone that their work had a lot or small pieces that they needed on the job.
    sailer
    sailer
    Number of posts : 2
    body style - windows and a panel in one Empty thanks Duane
    Post by sailer Thu Jan 16, 2014 1:07 pm
    Any idea how rare these were? Numbers produced?
    And the million dollar question... if I have to pull the motor - HOW?
    Post by G-Man Thu Jan 16, 2014 1:26 pm
    Sears and MA bell used them also, work vans and not as many of them because most were run to death. Most pull the motor thur the side doors
    Number of posts : 801
    Post by panelmanrd Thu Jan 16, 2014 2:19 pm
    there are three ways to pull the motor, one, out the pass front door,
    two, out the side cargo doors,
    three, out the bottom, I have done one and three with inline 6 and v8s
    never gone out the side cargo doors, if you have a lift, out the bottom is
    by far the fastest, but out the pass side door is not bad,
    if it is a 6 comes out with everything attached, if it is a v8
    you have to remove exaust manifolds/headers, fuel pump and spark plugs, and
    if you have tall valve covers they will need to come off also. if I remember correctly
    the temp sender in the head has to come out also. hope this helps
    gkpost
    gkpost
    Number of posts : 224
    Post by gkpost Sat Jan 18, 2014 1:26 pm
    I have a 67 that is the same as your van, All window on pass side and none on the driver side.
    I'll guess you have a 6 cyl, That's what mine has. Pull the motor out the bottom, take the front axel and leaf springs off, drop the motor and jack up the front of your van. Unbolt motor and trans , Pull the motor out the front wheel well. This might sound like a lot of work but its not. Have a friend or two to help or that motor will hit the floor. Also the more eyes the better.
    mikeysly
    mikeysly
    Number of posts : 284
    Post by mikeysly Sat Jan 18, 2014 2:57 pm
    i always pull my six out the side cargo doors
    Post by donivan65 Sat Jan 18, 2014 3:06 pm
    body style - windows and a panel in one Chevy_26
    Post by Twinpilot001 Sat Jan 18, 2014 3:52 pm
    I removed & installed my V-8 's thru the front pass door- ID never remove the springs & axle to do that -NEVER =way too much work for this old man!! Evil or Very Mad
    mo_1040
    mo_1040
    Number of posts : 645
    Post by mo_1040 Sat Jan 18, 2014 4:47 pm
    I went through the cargo doors... Piece of cake... Just had to extend the legs all the way out on my cherry picker.
      Current date/time is Thu May 02, 2024 6:31 pm
