I have been thinking of MAYBE upgrading the 65's drivetrain to maybe a late model Blazer V-6 or Tahoe V-6...Rear end, trans and motor mod,,,,anyone ever done this or heard of it being done???? Just throwin ideas out there....
Anyone ever do an upgrade on a "G" drivetrain??
I think you would have the same problem with the doghouse as you would have putting in a v8... The 4.3L are just as wide as a v8 but shorter so you would need to modify the doghouse. As far as rear end... if it's the right width you can make it work... welding on leaf spring perches to match those of the old rear end but make sure your pinion angle is right. Tranny shouldn't be a problem unless your using a newer one with overdrive then you would have to buy a kit to bypass the computer to lock the torque converter.
I say just go with a v8 and burn some rubber
another thing to think about being a shorter block a stock fan will be aways from the radiator and might not help much. I would think you would have to run a electric fan.
Well I am looking at either the V-6 ---T700- R-4 or the V-8 and tire Burner version,.....I seriously doubt that i keep the 6 banger-----As Im gonna have to do a ton of work... But may as well go for it,,,seein how i got it down that far... Don;t want a huge engine...just want to be able to cruise the hwyway and with trailer and not have to worry with power...Will probably do vintage AC in it also....Like the cool in summer....
Everything under this one will be address prior to lookin pretty! Mechanically she;ll be a driver!
DanTheVanMan- Commissioner
- Number of posts : 7900
Oh yeah. Ken's getting the "BUG"!!!
Always had it....jsut got to the point where it took charge!! bOUT TIME ,,,DON;T YA THINK!>..... dAN---tHE 69 I TOLD YA ABOUT I STILL THERE...May have to hit that guy up on the way home, and just damn get it!!! Tow it home on a car hauler!!!
WOO HOO,,,may as well hoard em while I can!!!!!!!!
Your right,,,bug is here baby!!!!
Ken,
Here's two for sale in GA. Ones in Canton and one in Americus, Ga.
http://atlanta.craigslist.org/cto/1039771682.html
http://atlanta.craigslist.org/cto/1015935247.html
