Would anybody happen to have templates for 1st Gen Stock radio opening with knob holes? And factory antenna on driver side above headlight? Also thinking about adding reverse lights even though I have a 65.
template's anyone?
Chevboner- Number of posts : 209
Registration date : 2012-09-15
template's anyone?
Re: template's anyone?
I might be able to help with the radio hole i don't think mine was butchered i will check Bob
A template: Great idea!
I would love to have an accurate template for the factory 1st gen radio antenna. I have a original 1st gen antenna, but I have not installed it yet, since I am unsure of exactly where the hole should be cut. I want to put it in the correct spot.
Can anyone help us out? I know there were original templates that GM put out. I believe most of the radios were dealer installed, so the hole for the antenna was cut at the dealership.
Panhead thanks for helping out!…
Kooky… I just bought one off ebay. I love the way they look. Thanks again for Helping with the wiring harness!
Sorry chevbone mine has extra hole drilled , and not sure if the square is modified also. If you want I will still take measurements if you want
Thanks Bob, maybe a picture would help?
