66ThunderVan
slowmotion
    Dog house ...............
    slowmotion
    slowmotion
    Number of posts : 30
    Registration date : 2013-09-04
    Dog house ............... Empty Dog house ...............
    Post by slowmotion Thu Nov 21, 2013 11:33 am
    Can you remove the dog house with no issues. I am worried that with out it. The floor may flex or warp. I would like to remove mine so I can get it sand blasted and painted. It looks like I can just un bolt it correct?
    Thanks
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Dog house ............... Empty Re: Dog house ...............
    Post by 66ThunderVan Thu Nov 21, 2013 11:42 am
    Yep, it's OK to take it out.
    slowmotion
    slowmotion
    Post by slowmotion Thu Nov 21, 2013 11:46 am
    Thanks. I figure as much as I like driving this. It will be worth parking it for a month or so to get her all cleaned up. I was worried about this the most. I will get it pulled out as soon as the weather clears up
    stanyon
    stanyon
    Number of posts : 147
    Post by stanyon Thu Nov 21, 2013 4:12 pm
    Crawl underneath and give all of the exposed threads on the bolts coming thru from the top a squirt of WD40 or something to help them out. If you don't you will most likely spin some of the clip on bolts and end up with a mess.
    Number of posts : 2011
    Post by Barnabas Sun Nov 24, 2013 4:30 pm
    It helps to have a friend underneath with vice grips.
    Murdock
    Murdock
    Number of posts : 313
    Post by Murdock Wed Nov 27, 2013 3:01 pm
    Just in case, those clips are still available and might be worth replacing a couple. Any good, local hardware store with a good fastener inventory should have them. Not the giants (HD, Lowes). The tabs on them will bend under a lot of pressure from trying to loosen them.
    Also available online. 5/16-18 captive nut
    http://www.ebay.com/itm/x10pcs-5-16-18-Cage-Nut-Black-Panel-Range-093-126-/200819405213
    slowmotion
    slowmotion
    Post by slowmotion Thu Nov 28, 2013 9:46 am
    Thanks. I was going to see if I could use new bolts and what ever else was needed when I put it back together. I will post a before and after picture of the dog house. It has a lot of heavy surface rust on it from the roof vent leaking on it.
    This never sends me notices of new post even with the box checked. Am I the only one with this problem?
    Post by Twinpilot001 Mon Dec 02, 2013 9:16 am
    Murdock
    Murdock
    Post by Murdock Mon Dec 02, 2013 10:02 am
    Thats a real good solution, do you have any pictures of them installed? I was looking for something similar when I was working on mine but the only thing I could come up with was hood/fender quick pins.
    Post by Twinpilot001 Mon Dec 02, 2013 11:59 am
    google =dzus fasterners-likely on ebay also & they come in different sizes & thicknesses- were used on all dragster & car panels from early 60's up!!
      Current date/time is Fri May 17, 2024 7:55 pm
