+4
A100 Wrench
chrisnben
8 posters
    V8 rad size & engine mounts?
    chrisnben
    chrisnben
    Number of posts : 38
    Registration date : 2013-11-12
    V8 rad size & engine mounts? Empty V8 rad size & engine mounts?
    Post by chrisnben Tue Nov 19, 2013 6:13 am
    Hi guys, recently scooped up my '69 A100 Scooby panel van & am doing a 340 swap from the leaning tower of anti-power & 727!
    Can anyone tell me the V8 measurements of the radiator? Or is it the same size? I'm thinking of getting a custom aluminum one made.
    Also, if anyone possibly has a set of V8 frame brackets (or templates to make some)- that would be swell bounce  In the meantime, I'm looking into Schumacher A-body /6 to V8 mounts.
    ~Ben
    V8 rad size & engine mounts? Empty Re: V8 rad size & engine mounts?
    Post by G-Man Tue Nov 19, 2013 10:20 am
    Welcome to VV!!!
    A100 Wrench
    A100 Wrench
    Number of posts : 572
    Post by A100 Wrench Tue Nov 19, 2013 7:35 pm
    Welcome
    Post by Big W Tue Nov 19, 2013 8:33 pm
    Welcome to VV chrisnben. Post a pic when you can, weed love to see it.
    Number of posts : 3046
    Post by RodStRace Wed Nov 20, 2013 8:41 pm
    There are pics of the engine mounts on here somewhere, I don't have them handey right now. As for the radiator, measure your existing opening and mount holes. They should be able to come up with something that works.
    chrisnben
    chrisnben
    Post by chrisnben Thu Nov 21, 2013 5:31 am
    I found (5) A100/ 108's in a nearby boneyard. Headed up there today for a looky. One is a window 108 van w/ 318/727. I might see what he wants for the whole deal and drag it home so all of us can chew off it Very Happy !!
    Anyone need some parts??? I do know there are no seats/ brackets, headlight rings.
    Number of posts : 1686
    Post by westcoastvanner Thu Nov 21, 2013 6:45 am
    What year? I need front doors, if they are in good condition and at least late 1968-70. I also could do with the side & rear barn door locking mechanisms.
    Post by Guest Thu Nov 21, 2013 9:58 am
    I think all the radiators were the same size as it is in a tight space. Aluminum rad tech here. https://vintage-vans.forumotion.com/t33813-whalemstr-or-dan-s-fsr-radiator-replacement-for-67-dodge-a-100?highlight=fsr+radiator
    Number of posts : 8731
    Post by dix Thu Nov 21, 2013 1:35 pm
    I have the engine brackets if you still need measuremants, a lot of people just cut gown the drivers side. But i don't know if the engine / motor mount location changed ??? or are they the same as a 318 ???
    chrisnben
    chrisnben
    Post by chrisnben Thu Nov 21, 2013 6:13 pm
    DIX- would you sell me the 318 brackets?
    I'm pulling the /6 this weekend and I'll see if the conversion mounts fit up to the / brackets first.
    Nice info on the FSR radiator too! I also talked to Northern Radiator out of MN. Speedway Motors sells this unit for $249. It should fit nicely for the V8- 318 as well #917-5159 (measures 19-3/4 x 27" tall)
    http://www.speedwaymotors.com/Universal-Aluminum-Radiator-27-Inch-Tall-Passenger-Side-Outlet,7316.html
    the optional shroud is $50 from http://www.hrperformanceproducts.com/endrfanshki.html; #Z40022
    chrisnben
    chrisnben
    V8 rad size & engine mounts? Empty radiator
    Post by chrisnben Tue Dec 10, 2013 11:02 am
    the Speedway radiator & shroud are IN and fits beautifully! Just had to trim the opening on the rad support a tad for the upper hose to come through.
    Great deal for $249; shroud $60.
    rad #917-5159
    shroud #917-4022
    ndjarrett
    ndjarrett
    Number of posts : 357
    Post by ndjarrett Tue Dec 10, 2013 11:59 am
    chrisnben wrote:I found (5) A100/ 108's in a nearby boneyard. Headed up there today for a looky. One is a window 108 van w/ 318/727. I might see what he wants for the whole deal and drag it home so all of us can chew off it Very Happy !!
    So did you get it? I assume the 727 is a short tail shaft? Any interest in pulling & seeling just the tailshaft section?
    Post by dix Tue Dec 10, 2013 2:42 pm
    Chrisnben not sure how i missed your post , sent you a pm.
    chrisnben
    chrisnben
    Post by chrisnben Wed Dec 11, 2013 6:02 am
    I will be going back to the boneyard as weather permits (above 25-30)- which might be a while affraid
    the one 318 window van had the engine/trans sitting nicely on the floor as someone already robbed the mounts, etc. Nice dash cluster, armrests, auto shifter though. I will list parts for sale in A section here as I get them. Not looking for much, just helping out us Dodge guys. rendeer
    I sold my /6 and trans, but he's switching the tailshaft for a car install, so I could see if he'll sell it to you. It should be the same tail on both /6 & 318 A100.  Cool ~Ben
    ndjarrett
    ndjarrett
    Post by ndjarrett Wed Dec 11, 2013 6:19 am
    chrisnben wrote:I sold my /6 and trans, but he's switching the tailshaft for a car install, so I could see if he'll sell it to you. It should be the same tail on both /6 & 318 A100.  Cool ~Ben
    Sounds good. Give him my info. I got a long tail shaft 727 with a 383 I picked up. Not 100% sure I wanna go auto...but would be nice to have the short tail if I do. :-)
    Post by RodStRace Wed Dec 11, 2013 8:13 pm
    Just remember you need the output shaft (gotta pull the whole guts out) AND the outer housing...
    ndjarrett
    ndjarrett
    Post by ndjarrett Thu Dec 12, 2013 4:28 am
    RodStRace wrote:Just remember you need the output shaft (gotta pull the whole guts out) AND the outer housing...
    Yup :-)
      Current date/time is Sat May 11, 2024 3:45 pm
