The a100 pickup I bought had engine problems ( knew this when I bought it. thats OK ) possible head gasket 273. I'll be pulling it this weekend. I'm one of those people that prepare for all different out comes.
I've got a question for you veterans of a100s . Of the two V8s (273/318) which should be the better choice for MPG ?
273 small cubes/less lowend/ pulling a truck that has the aerodynamics of a brick. Or the 318 more cubes/ more lowend / pulling a brick down the road.
My thoughts on this is, you have to work the 273 harder (less torque). But since the 273 is smaller C.I. (less demaned for fuel) But what do I know ?
I have a 727 with a 3.23 ratio/ dual exhaust
Just looking for what you guys think, if there would be much if any difference in MPG. Don't really care about the power difference so much. But then again I have not even driven this thing yet.
If when I pull the 273 down and find problems (bad worn cylinder walls/needs pistons:affraid: ) I'll be installing a 318.
Last edited by rustytoolss on Fri Nov 01, 2013 3:05 pm; edited 1 time in total (Reason for editing : info)
