    Column Bearing
    Number of posts : 209
    Registration date : 2012-09-15
    Column Bearing Empty Column Bearing
    Post by Chevboner Tue Oct 22, 2013 3:46 pm
    Brother's offers this bearing for 1960-1963 $19.99 and one for 1964-1966 $34.99 they look exactly the same only thing is price. Does anyone know if there is a difference? could i buy the cheaper one, or do i need the recommended year?
    http://www.brotherstrucks.com/products.asp?dept=658
    Column Bearing Empty Re: Column Bearing
    Post by donivan65 Wed Oct 23, 2013 10:42 am
    Those bearings are part of the turn signal switch,,,,,,,Corvair will sell you the whole switch for about $35,,,,,,,,Corvette will probably want over $100 for the same switch,,,,,,,I will send you one of these used bearings if you want
    Column Bearing Repair16
    Number of posts : 1046
    Post by VANagain Sun Oct 27, 2013 10:01 pm
    I bought a bearing like that on eBay for about $25 and then later learned, as Don says, it comes with the turn signal switch. I went with the whole switch, so now I got this spare bearing. Want to buy it?! I'll sell it to you for $15! Smile
      Current date/time is Sat Apr 27, 2024 9:35 am
