I installed the brake pedal relay kit from bowtie overdrives on my newly installed 2004R. I tapped into a white wire that goes to my brake light switch. I'm assuming its functioning correctly because I can hear the relay clicking when I press on the brake pedal.
Only thing is it only makes a clicking noise when the headlights are turned off. Did I tap into the wrong wire?
