Got my new gauges put together.
The old wiring is out and new is going in.
Got my rear seat belts mounted.
Started installed the new steering wheel.
Ya...lol...that's how it was when I bought it. When I took it off and sealed everything up better, I was gonna flip it around the right way...but I forgot.jbass62 wrote:Looks great, question, which way is the rear hatch facing? looks like the hinges are towards the rear which would make it open like a scoop? I just bought a similar one to replace the broken one the PO put in and I thought it should open to the rear with the hinges in the front, wouldn't high speed air tend to rip it open if its hinges at the rear? I would be a good way to force air into the back on warm days that way? Also, I've got a monster oversize dash hole too that I have to make a similar faceplate for the radio, looks there was a ham radio in there or something, my hole is 9" x 4"!
They worked with the factory wire harness. I put in a whole new AmericanAutoWire kit. So, they should be good, but if the new switch don't work, I will check those connections again (but since tail lights do work, idunno if that's where it is). I will also dbl chk what the kit calls for bulbs, maybe it uses little different than the van had originally? Like I said, the fun begins.jbass62 wrote:Regarding brake lights, remember, assuming all the front to back wiring is OK, they route through the turn signal switch, and those contacts in there wear out over time. I had to replace that as well as the brake switch to get mine working properly. The pedal switch has a gasket in there that dries and shrinks over time allowing corrosion of the contacts, that's what I found when I opened it up.
