by RodStRace Mon Sep 02, 2013 7:53 am
Twinpilot, you and I gotta have a sit down and have a couple beers someday!
Blackace, he's right. I'd also guess an electrical issue is most likely, but if you don't know how to check dwell and timing, it will be hard to explain how to diagnose an intermittent stall issue.
it's a bunch of stuff you can learn, heck WE did and we were doin' stuff back then that was not great for learning and memory! You list your age as 50, so at least you were around back then and know these things didn't die all the time.
Start with the basics; How to do a full tuneup. You have great reference material with manuals and videos. The meters are a lot better too. Then increase that with some electical and fuel diagnostics. Vintage stuff is a lot simplier than newer stuff, but it's old, worn and has been messed with for many years. It's almost always a simple fix, you just gotta know what to look for and how to find it.
I found this series of xideos showing how to test a circuit using the voltage drop method. I've reviewed the first 3 and they are great.
https://www.youtube.com/watch?v=6Sqk_Gai59II hope this helps. I'm going to write up a thread on this and put it over in the This Is How It's Done section.
