by RodStRace Thu Aug 22, 2013 5:50 pm
Coming form a Mopar background, I'll share the typical car fixes. I don't know how much of this straight applies to vans, so consider this for info only.
First, the Mopar design was built to control this better than the other guys. The axle was not centered on the leaf spring, but moved forward, making the front segment shorter and stiffer to counteract this issue, while the longer rear segment sofetned the ride.
The old school factory recommended HP fix was super stock (STIFF) springs and a pinion snubber. This was bolted on the center section of the rear axle and had a rubber bumper much like the one on the frame rails above the axle. This would keep the axle from wrapping up and hopping.
The aftermarket 'slapper bars' were looked at by Mopar guys as poseur parts. They worked okay on other brands that did not have the unique axle placement, but not so much on Mopars. Some guys did have decent experience with them however. It must be said that the bumper on the forward end should extend to under the spring eye, not hit part way in the flat section. This has caused leaf failures in some extreme limited cases.
One solution that has come out in the past 10-15 years are CALTRAC bars.
http://calvertracing.com/caltracs.phpThey are similar to slapper bars to a casual glance, but they are different.
This is the big step between a good stock setup and tearing it all out and welding in a different design.
So best of luck on finding a solution!
