    brake lines
    hometeam
    hometeam
    Number of posts : 101
    Registration date : 2013-01-21
    brake lines Empty brake lines
    Post by hometeam Sun Aug 18, 2013 8:57 am
    i was driving van blew a front tire and the radial belts clipped the brake line. was able to get van home but need to replace brake line - looked online but having trouble finding part
    any help would be appreciated 67 a1o8. thanks
    Number of posts : 2036
    brake lines Empty Re: brake lines
    Post by dodge man Sun Aug 18, 2013 9:37 am
    i forget the part # but check with carquest. thants were i got all mine before i did the disc brake conversion,
    Post by donivan65 Sun Aug 18, 2013 10:09 am
    Here is what I use to replace the brake lines on Chevys,,,,,,it at least has some part # and sizes on it,,,,,,,
    brake lines Brake_10
    mattimuss
    mattimuss
    Number of posts : 205
    Post by mattimuss Sun Aug 18, 2013 10:30 am
    Which brake line is it?
    How far are you from San Diego?
    I fabbed all new brake lines for my van, if you have the old one we can make a replacement.
    "We have the technology!"
    Matt
    hometeam
    hometeam
    Post by hometeam Sun Aug 18, 2013 4:11 pm
    it was the hose from metal line to brake cylinder that was damaged - mattimuss when i get hose line repaired i would like to set up a time to redo all metal lines like you did- i am 90 minutes north of you in mission viejo. dodgeman - i will check out carquest
    Number of posts : 8731
    Post by dix Sun Aug 18, 2013 5:08 pm
    make sure you soak those lines before you attempt to remove them or they will just twist/ brake apart..
    hometeam
    hometeam
    Post by hometeam Sun Aug 18, 2013 7:11 pm
    the tire blowout did the damage ~ i am blessed all the damage was a brakehose and a tire. i was on freeway going about 60 at 4am heading to a swapmeet when it blew - open freeway with a severed brake line allowed me to coast and ebrake it to safety.
    mattimuss
    mattimuss
    Post by mattimuss Tue Aug 20, 2013 8:20 pm
    Contact me via PM and we can start to coordinate making this happen.
      Current date/time is Fri May 17, 2024 1:56 am
