    Bridgers Wyovan update!
    WyoVanBridger
    WyoVanBridger
    Number of posts : 6
    Registration date : 2017-10-21
    Bridgers Wyovan update! Empty Bridgers Wyovan update!
    Post by WyoVanBridger Mon Sep 03, 2018 8:26 pm
    Hello Everyone! Its been a while since I posted an update on the van so I thought I would do so! So much has changed I decide to make an entirely new post. The last time everyone saw the van I had just got it running and was working on the outside aesthetics. I decided to change pace on the outside and stick with the rustic pain job with imperfections and all. I with the help of one of my close friends decided to tackle the inside of the van with a multi-purpose camper can theme in mind. The white spaces above the license plates is going to be filled with the paintings of the Tetons and Wyoming desert. The walls and floor are fully insulated and the roof is next on the list. On the mechanical side the exhaust was shot so I decided to go with twin side pipes, I knew from the start that the engine was tired and in time was going to need replacing, so I picked up a 350 small block that I am going to rebuild and slap in it. Exterior wise not much is left to change besides putting a new front and rear bumper on. I will keep everyone updated with progress
    - BridgerBridgers Wyovan update! Img_2012
    Bridgers Wyovan update! Img_2010
    Bridgers Wyovan update! Img_2011
    Bridgers Wyovan update! Img_2014
    Bridgers Wyovan update! Img_2013Bridgers Wyovan update! Img_2016
    Bridgers Wyovan update! Img_2017Bridgers Wyovan update! Img_2018
    Number of posts : 1388
    Bridgers Wyovan update! Empty Re: Bridgers Wyovan update!
    Post by wideload Tue Sep 04, 2018 5:43 am
    Bridgers just a hint, if you use the 640 pix setting when you post a pic it won't get chopped off.
    Good looking van !!!!!!!!
    Post by vanny Tue Sep 04, 2018 8:35 am
    Bridgers Wyovan update! Bridge12
    Bridgers Wyovan update! Bridge11
    Bridgers Wyovan update! Bridge10
    Bridgers Wyovan update! Bridge13
    Bridgers Wyovan update! Bridge14
    Bridgers Wyovan update! Bridge15
    Bridgers Wyovan update! Bridge16
    Bridgers Wyovan update! Bridge17
      Current date/time is Wed May 01, 2024 2:47 pm
