    AT/MT fuel systems
    AT/MT fuel systems Empty AT/MT fuel systems
    Post by Guest Thu Jan 29, 2009 6:19 pm
    hello all. im just wondering here,
    what are the differences in a carb that is designed for automatic and one that is for manual trans?
    if one gets a carb that is "for automatic" and puts it on a vehicle with the manual trans, what is the down side of this?
    and also viceversa, if one gets a carb for a car with stick trans and puts it on an automatic?
    also, if the carb is for a 200 cid engine and one uses it on a 144 cid motor, or a 170? is it bad performance?
    less mpg? more things to worry in the long run?
    just a thought
    AT/MT fuel systems Empty Re: AT/MT fuel systems
    Post by Guest Thu Jan 29, 2009 6:50 pm
    same carb on the 170 and 200
    Post by Guest Thu Jan 29, 2009 8:34 pm
    even if they are automatic or standard?
    what about a 240 to a 200?
    Post by Guest Thu Jan 29, 2009 8:36 pm
    Post by Guest Thu Jan 29, 2009 8:38 pm
    Post by Guest Thu Jan 29, 2009 8:39 pm
    Post by donivan65 Thu Jan 29, 2009 10:49 pm
    The automatic carb would have more vacuum lines and a different linkage to allow for the trans vacuum lines or kick down cables to be mounted to it. They would be set up with a different float level to allow the engine to not die at idle when you shifted into drive or reverse. And you might find that they would be set up for an automatic choke also. But if I had to guess, you might not notice much of a difference if you put an automatic one on a stick shift van.........
    Number of posts : 2067
    Post by sasktrini Thu Jan 29, 2009 11:26 pm
    You are sending me to school on that one Donivan... makes sense and never thought of that question before... good one beanses... I love VintAGE-Vans!!!
    Post by Guest Fri Jan 30, 2009 4:03 pm
    im in love too!
    with vans and the people in this site. but lets not get sentimental hahaha
    so any of those carbs mentioned above are good for a ford 200?
      Current date/time is Sat May 18, 2024 7:32 pm
