I know this has been discussed and I've read all econoline wheel size related threads. But... while I was changing my shocks and looking at the worn out tires on my rig I thought, spend $ on new tires which she desperately needs, or throw that money towards getting some sweet rims And I've kind of set my mind on some cragar style rims, ar etc in 17" size.
I found a link to a calculator that has been extremely useful in helping me figure out what wheel/tire combos will fit:
www dot rimsntires dot com/specs.jsp forum won't let me post hyperlink yet
It may help some others out in the future.
The van currently has 195/75/14's on stock-style 14"x6" steelies with what I'm pretty sure is a 4" backspace.
That yeilds a wheel that is 7.7" wide x 25.5" tall overall with offsets of 3.35" frontside and 4.35" backside. These wheels fit with room to spare and don't fill out the wells much, esp in the width dept.
So after some, hopefully, careful measurement and calculation I've come up with what I think I'm going to go with.
Fronts- 17"x8"/+.5" offset and 225/45 rubber which yeilds a wheel that is .6" wider both sides than the current wheel in position and .5" smaller in diameter. Looks to be no problem lock to lock turning.
Rears- 17"x9"/+.5 offset and 255/40 rubber which yeilds a wheel that is 1.15" wider on both sides and also .5" smaller in diameter. Looks to be an easy fit as well.
Here's the thing, I'm also considering going with 225/50's up front and 255/45's in the back which would give me +.4" front and +.6" diameter back over current wheels which I think will be fine. But I'm thinking about lowering the van some and not sure which ones to choose.
What do you guy's think?
